Question about Samsung SGH-E500 Cellular Phone
MMS Unknown Subscriber
Hi can anyone help me i am unable to send or receive mms my provider has allowed me to but all i get is a message on my phone that says "unknown subscriber" can anyone please help me?
5 Suggested Answers
  • 123 Answers
SOURCE: i cant send nor receive pictures
Hi Kim, Contact your provider and ask them to send you there WAP and MMS settings, usually when you recieve theese you switch off your phone, power it back up and YOU need to send a picture to activate the MMS settings with your provider. Good Luck!
Posted on Feb 15, 2008
SOURCE: smasung g600
On your phone go to Settings - Message Settings - Multimedia Messages - Multimedia Profile and pick one of the profiles (probably # 5 is open).
Profile name - Multimedia
Server URL -
Proxy - Enable
GPRS Settings (open it)
IP Address -
Port - 8080
APN - wap.cingular (case sensitive)
LOG ID - CINGULARGPRS.COM (case sensitive)
Pasword - CINGULAR1 (case sensitive)
Try this it worked for me
Posted on Feb 25, 2008
  • 544 Answers
it means that your GPRS settings are not activated.
you can contact your sim service provier to activate it for you.
Posted on Mar 30, 2009
  • 42 Answers
SOURCE: Cannot open mms photos/images
call your mobile sim provider and ask for the activation of your GPRS to received a mms..
Posted on Jul 03, 2009
  • 34 Answers
SOURCE: I can't receive ANY MMS on my B3410! HELP please!
try to open your mms through operator then they guide you what step will you do then wait an hour to active your mms setting
Posted on Jul 26, 2010
0 characters
1 Points
Mms does not work, i am UNABLE to send pic msgs. plz help
I suppose you havenot got the MMs settings from your service provider.
Please call your service provider and ask for the settings. When they send it please save it to your phoneand make it as a default settings so that your phone uses this setting when you send MMS.
In settings there is an option called as ALLOW MMS RECEPTION, please put this to ON,
To go to Allow MMS RECEPTION option follow the steps
Menu----->message----->message settings----->MMS setting------>allow MMS reception
Now you can use MMS
Jul 18, 2010 | Nokia e65 Cellular Phone
My son tried to send me a photo of our grandaughter to my mobile but when i try to view it it comes up with a message unknown subsciber have a samsung d900
Hi, and welcome to FixYa!
I've been doing some research on your problem of not being able to receive MMS messages (pictures) on your phone. There are a couple of reasons why you may not be able to. I'll list them in order:
1) Your cellular provider may not have MMS activated for your phone. Contact your provider and ask if MMS is enabled on your line.
a) If they tell you, no - it is not currently enabled, then ask them to enable it for you.
b) If they tell you, yes - it is currently enabled, ask to speak to someone in Tech Support. Inform Tech Support that you are not receiving MMS messages but instead, an 'Unknown Subscriber' message although you have MMS currently activated on your line. Most Tech Support Departments can send a 'packet' to your phone that you will simply click on when you receive it - and download it on your phone. That should solve the problem.
There is one more problem I discovered. If the picture you are sent is too large for your phone's screen to display you might also receive this, 'Unknown Subscriber' message.
Regardless, your first call should be to your cellular provider to ask assistance with your MMS settings.
I hope this information will help you.
Feb 04, 2010 | Samsung SGH-D900 Cellular Phone
Mms troubles
go to multimedia - then go to settings - then go to MMS profiles - then current profile - set wat service u need
Dec 14, 2008 | Samsung SGH-D500 Cellular Phone
Everytime i get sent a picture in a text, but when i try to open it, the phone says unknown subscriber and will not let me open any of the MMS texts i recieve.
Ring your network they will send you a code which you can save and it will allow you to recieve mms picture messages.
Hope it helps
Oct 08, 2008 | Samsung Cell Phones
Razar v3xx
When you receive the message with id and password, it usually means that either your phone is not multimedia messaging compatible or your account is not provisioned with the actual multimedia messaging feature itself.
If unable to send or receive a picture message (MMS), troubleshoot accordingly:
  1. Attempt to connect to MEdia Net on the device. Connectivity to MEdia Net confirms the device has enough signal strength and GPRS availability to send and receive MMS.
  2. Verify MMS is being sent to an AT&T subscriber. If MMS message is being sent to someone other then an AT&T wireless services subscriber, verify that the carrier is supported.
  3. Picture messaging settings are pre-configured on all devices purchased from AT&T. If the settings have been altered or if the device was not purchased from AT&T, validate picture message settings are properly configured.
  4. Attempt to send an MMS again.
  5. If further assistance is required, please contact Customer Care.
If problems occur, please perform the following troubleshooting steps:
  1. Verify device has signal strength.
  2. Check for a GPRS attach on the device.
  3. Verify the browser settings are correct.
  4. Clear the browser cache.
  5. Power cycle the device (turn off and back on).
  6. Attempt to access MEdia Net again.
  7. If unable to access a particular MEdia Net site, check to see if the site is supported by AT&T.
  8. If problem persists, please contact AT&T Customer Service for wireless customers.
Jun 08, 2008 | Motorola Mobility RAZR V3
I cant send nor receive pictures
Feb 13, 2008 | Samsung SGH-E900 Cellular Phone
Picture messages
what's your network provider?
ask them to send you a settings of GPRS and MMS so you can send and receive images. ok...
Dec 01, 2007 | Samsung SGH-D900 Cellular Phone
Mms messaging on samsung d600 camera phone
First thin to send MMS that it shud be activated and u have all setting from ur service provider, like apn, home url, ip address port number etc...after doing all just try to send first mms to ur own number...thanks
Oct 22, 2007 | Samsung SGH-D600 Cellular Phone
hi kim
the issue might be from ur service provider's end check out the settings if the settings are all right than consult with ur SP
Oct 15, 2007 | Samsung SGH-D500 Cellular Phone
Samsung SGH-E500 Cellular Phone Logo
1,804 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
