Question about Acer Aspire 5500 5570-2609 Laptop
Computer startup problem
I deleted a system file recently. Now Windows has become inaccessible. I can't access F8 or safe mode. Bios set up is accessible and also msdos prompt but i dont know how to use it. Pls. help me restore that deleted file' It is now in the recycle bin. Thanks a lot.
    Champion:
  • 209 Answers
Go to the recycle bin then right click with your mouse the file you deleted then click restore. the file will be restored.
Posted on Jan 19, 2008
Toshiba satellite is stuck safe mode it's running Windows XP.I tried restart f8 start normal a black screen with bunch stuf& starts in safe mode. What's wrong how can I get it out of safe mode?
First you should really consider upgrading from Windows XP because it is no longer supported and the chances of your computer becoming infected are extremely high.
Pressing the F8 command will only access Windows RE where you can access startup repair safe mode etc.
If the computer is only allowing you to go into safe mode that is a good sign that something is severely wrong with your OS.
While in safe mode you should try and access system restore, but this will only work if 1) you have turned on system restore and 2) your system has a restore point to access.
Have you added any new hardware or programs to the computer? If yes, then the new addition may be the cause of this issue. You can use device manager to rollback any changes or access programs and features to delete any program changes.
Other then that, if none of the above suggestions work I would strongly suggest booting from the disk media to access Windows RE too recovery the computer or just to re-image the computer.
Hope that helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Nov 08, 2015 | Toshiba Computers & Internet
After I power on HP Hewlett packard laptop what keys can I use to access startup menu
If you mean BIOS startup menu, DEL or F1
if it's windows startup menu
for XP your computer restarts but before Windows launches, press F8
For Windows 7, follow this tutorial
Need to Start Windows 7 in Safe Mode Here How
For window 8 follow this tutorrial
5 Ways to Boot into Safe Mode in Windows 8 Windows 8 1
If you means something else by startup menu, please be more specific
May 12, 2015 | HP Computers & Internet
Windows does not start up.error code 0x0
Try booting into "safe mode" It's hard to catch safe mode, but after your computer just powers on, press the F8 key and hold it. If you get a keyboard error you did it too soon. You should see something which says advanced boot options. See if you can boot into safe mode and transfer your files to a USB key or USB drive. It sounds like your software is messed up. If you're not able to boot into safe mode, the problem is more serious. Perhaps you recently made some changes in the bios or UEFI? When the system boots hold down the delete key, or the F1 key, and try to get into the bios/UEFI. Look for an option which says "restore defaults", save and exit. There are two different settings for SATA drives, try both to see if you can get your system to boot.
Dec 26, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I cannot start up my acer aspire 584g32bn
Safe Mode and System Restore can fix startup issues in an Acer Aspire One, but if the computer won't even load the boot screen, the problem could be related to the basic input/output system (BIOS).
The Acer Aspire One 110 and 150 are two models that can have BIOS-related problems that prevent the computer from booting.
You can upgrade the BIOS through a USB flash drive to repair this issue.
If you are able boot past the startup screen, but can't sign in to Windows, you can use Windows Advanced Boot Options to bypass startup problems.
Go to the Acer website (see Below).
http://us.acer.com/ac/en/US/content/drivers
Click "Support," then select "Download" from the menu on the left.
Select "Netbook" as the product family.
Click "Aspire One" as the product line. Select "AOA110" or "AOA150" as the product model.
Click the "BIOS" tab.
Click the download button and save the file to the desktop.
Go to the desktop when the download completes.
Double-click the file to open it.
Drag-and-drop the folder to the desktop.
Double-click the folder to open its contents in Windows Explorer.
Double-click the "BIOS_Acer_3310_A_AOA110 & AOA150" folder.
Double-click the "Dos_Flash" folder.
Insert a blank USB flash drive into a USB slot.
Drag-and-drop the "3310.fd" and "Flashit.exe" files to the flash drive.
Right-click the "3310.fd" file. Click "Rename."
Change the file name to "zg5ia32.fd" and press "Enter."
Connect the AC adapter to the power jack.
Hold down "Fn" and "Esc" with one hand, then press the power button with the other.
Release the "Fn" and "Esc" keys when the power indicator light comes on.
Wait at least seven minutes for the system to fix the BIOS and repair the Acer Aspire One startup issues.
The computer will restart automatically when the process is complete.
Other Models
Turn on the computer.
Press "F8" before the Windows logo appears to access the Windows Advanced Boot Options menu.
Scroll to Last-Known Good Configuration.
Press "Enter" to load Windows.
If the OS fails to start up, hold down the power button for 10 seconds to turn off the computer.
Press the power button to turn the Acer Aspire One back on. Press "F8," then select "Safe Mode" from the options.
Log in to Safe Mode. Click "Start," "All Programs," "System Tools" and then "System Restore." Click "Next."
Select the last working restore point from the options. Click "Next."
Click "Finish" to run System Restore and recover the Acer Aspire One to a previous state.
Apr 21, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
HP I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update? HP Probook 4530s
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
hope this helps
My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
The issue may be due to any recent hardwrae or software changes and also due to any virus.
1. Remove any recently added hardware/software.
2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
Nov 07, 2010 | Sony VAIO Notebook
The laptop purchased from India at present with my daughter studying at Brisbane and repaired by service centre sydney of acer company shows ' we apologise for the invonvenience but windows did not start...
1. Please reset the BIOS to its defaults.
2. Restart the Computer , press F2 or Del key at startup to access BIOS.
3. Press F9 key to restore the default values and press F10 key to save the settings.
4. Restart the Computer and press F8 key to start the Computer in Safe Mode.
5. If the Computer boots in Safe Mode, you can perform the System Restore.
6. Please click on Start, All Programs, Accessories, System Toots, System Restore and select the restore date.
7. If this does not resolve the issue, you can reinstall the Operating System using the Restore Disc provided.
Jun 23, 2010 | Acer Aspire 3680 Laptop
Acer 5620 pressing f8 at start wont load bios either
F8 is usually reserved for Windows Safe Mode. BIOS settings are usually found with by pressing ESC, Delete, or F2 on most system. Some times I run my finger along the entire row of function keys like a piano if it isn't specified which key works during boot up.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
Computer Lock Down
Force your computer to start in Safe Mode. To do that, hold down the F5 key when you start up and keep holding it until you see that your PC has booted to Safe Mode. (Another way to do this is to hold down the F8 key during boot time until you’re presented with the Windows Startup Menu and then choose Safe Mode from the list of options presented there.
When you’re in Safe Mode Windows skips the Config.sys and Autoexec.bat files and loads a minimal set of drivers that lets your PC function at a basic level. Then do a systme restore while on safe mode......
Hope that helps..........
Jul 04, 2008 | Sony Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
