Question about Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Can't Power Up
I'm having trouble powering my laptop up. The battery is dead so it should still work with the power supply but it isn't. I tired these steps posted by Acer
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=1125&formid=3390&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
and had no luck. The only thing that happens when I push power is the yellow light in the front will flash for a second & that is it. I have a feeling now that it's the power supply cord, but dang, it's not that old. I bought it a few months ago on Ebay. Do they just die or what? Not sure how to test it either if that is possible. Is there a certain power supply that I should buy that will last longer than a few months! The original one that came w/ the laptop frayed on me. I'm not having any luck w/ these darn cords!
  • k1ahmed Mar 22, 2008
    I have some problem and have a good power cord. Exact same thing - light flickers but won't turn on. I don't know how to get the internal power supply out. may be that is fried. I blowed compressed air to make sure that inside there is no dust. I also pulled on wires inside for any loose connection,
    Don't know where the power supply pin is to the mother board
Acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Posted on Jan 15, 2010
If any of you purchased an Acer Aspire 3680 laptop about 3-4 years ago and it has had problems with the power port - you can get new parts and repair it yourself fairly cheaply. Youtube user maxcom83 has excellent how to videos on how to do it. You will have to purchase a new duaghter board.http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-5580-Power-Board-w-dc-jack-/130420466707?pt=LH_DefaultDomain_0
Posted on Aug 17, 2010
    Sergeant:
    Champion:
  • 244 Answers
Check the power pin in motherboard, It might be broken/loose.
Try to remove battery and power on.
Posted on Jan 19, 2008
3 Suggested Answers
SOURCE: acer travelmate 3210
yes theres a solution. go into your bios go to booting preferencess click f-9.
them press enter then press esc when it prompts you to exit saying the changes click yes.
when your sys reboots and all is well. reboot it again. second time it boots ok.
there you go.
Posted on Dec 30, 2008
  • 122 Answers
SOURCE: My laptop is acer travelmate
shut down pull the battery out try to find out where the cmos battery is . you scrambled the bios. i you can pull out the cmos battery out and can put it in again( a small watch like battery on the motherboard. ) put the main battery in again the big recharge able battery. and see if it boots up . If it does don't mess with the bios you may have the wrong version. If it aint broke don't fix it
Posted on Dec 31, 2008
ACER 3680 battery does not recharge. I have replaced it twice. Can you help?
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 07, 2009 | Acer Aspire 3680 Laptop
Power supply jack on Acer Aspire 3680 Laptop not macking connection. checked power supply and it is putting out 19.2 volts. How do I go about changing jack?
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot fix this yourself then I suggest you get a quote first.
Nov 03, 2009 | Acer Aspire 3680 Laptop
NO POWER
Heyy don't panic. I know its very costly to replace mother board or power supply SMPS. And i assures you that neither its mother board problem nor power problem. Its a problem with your RAM only. If RAM is faulty then laptop starts giving same problem.
So, please go & replace your RAM. Its not that must costly also. So you can easily afford also and new RAM will boost the performance of your laptop.
Rate this solution if it was helpful to you.
Apr 27, 2009 | Acer Aspire 3680 PC Notebook
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 will not power on battery and powercord are new
The battery is dead and/or your powersupply isn't working properly, or your memory is loose. first open the little door on the back where the ram is at and reseat it, then try to power it on, if that doesn't work take it to a professional nad have them test the power supply, if it tests ok, see if it is under acer warranty (acer.com) if it is send it in, if it isn't goto tigerdirect.com and buy a new one for around 300.00 don't waste any money on that computer.
Dec 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
I cannot power on the computer. It is an acer aspire 3680.
the Power supply may have gone bad, worse case scenario, the motherboard died on you
Dec 07, 2008 | Acer Aspire 3680 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
1,853 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
