Question about Canon PIXMA iP6700D InkJet Photo Printer
Step by step on how to do duplex printing on Pixma iP6700D.
I am having difficulty learning how to do duplex printing on the Canon Pixma iP6700D.
SOURCE: canon pixma mp210
actually I have a MP220 but I guess it won't change very much. I spent some 5 hours in downloading all possible drivers and in trying installation several times without my computer being able to recognize the machine. Even without installing the drivers try to plug in your printer. IF WINDOWS XP TELLS YOU THAT NEW HARDWARE IS UNKNOWN THEN LOOK NO FURTHER: CHANCES ARE THAT YOUR USB CABLE IS NOT GOOD. In my case i bought it brand new from a shop and I realized it was USB 1.xx instead of 2.xx. I was skeptical but I substituted it and the problem was solved.
Posted on Jun 03, 2008
SOURCE: Need a help for Canon PIXMA® MP470 Printer
My printer wont print. It flashes Error 5100 and the orange light flashes twice. There are no answers in the book.
Posted on Jun 28, 2008
  • 22 Answers
SOURCE: Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
Posted on Mar 15, 2009
  • 111 Answers
SOURCE: canon pixma mp240
Thats simple click here
rember vote for me.
Posted on Aug 07, 2009
  • 2306 Answers
SOURCE: Black line on back of paper printed by canon pixma
You will need a shop to dismantle the printer, the ink is being forced up onto the exit rollers from below. It needs a good cleaning plus a mylar shield installed to keep that from happening again.
Posted on Dec 18, 2009
SOURCE: printer cannot print-message (5B00)
it says check printer 5B00. what do I need to do?
0 characters
1 Points
My canon ip6700d cannot correctly detect the ink level in one of the cartridges. How can I fix that problem?
Hold down the (red) Stop/Reset button until the message disappears from the printer display.
Then clear all jobs from the print queue (select and cancel each job). Then resubmit a print job.
May 16, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Thje tag said this was a free service!!
There might be a problem with the printhead
if it been sitting along time ..days....some of the nozzle could be clogged are beyond cleaning
Feb 03, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
Paper jam, Canon iP6700D
your printer have to be opened so please take it for servicing
Nov 06, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
How do I reset the left margn on my canon ip6700D printer
Margins are set in printing preferences in the window that pops up after you press print. If prints like the nozzle check are off center you need to clean the encoder strip.
Nov 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Black text not printing!
You need a new printhead, QY6-0063-000. The instructions are packed with the new printhead.
Feb 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
My IP6700D prints some color but with a green cast
Someone forgot to peel the tape off the PM cartridge, must have been me.Thanks
Jan 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Canon Pixma 4200 does not print double-sided with Mac
First, I'd strongly suggest you update your drivers.. there are newer drivers that came out in Nov 07, Dec 07, Jan 08 and even Feb 08. Here's the link to Mac OS drivers for your specific printer...
Please download and install all of the applicable drivers/software, because I have found that features such as color management come from the Easy Photo software, not the driver stuff.
The second link here is the directions on how to set up the duplex printing in Mac OS systems. It's a step-by-step and seems pretty comprehensive.
Good Luck!
Let us know how it works out for you!
Maggie B
Feb 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
i have a ip6700d.the problem is that im trying to scan but it cant connect to the machine. what's the problem?
Feb 19, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
44 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
