Question about Lands Phones
My Calisto Pro drops SKYPE calls
Hi:
I'm trying to use my headset from Calisto Pro with Skype and it always drops the call. I'm using Vista - I've tried two different headsets from Plantronics with the same problem - so I'm thinking there is a setting or something in Vista that is causing this? Can you help?
Kathy
  • vakathy Feb 11, 2008
    Yes, and per Plantronics, I uninstalled both Skype and PersonoCall and reinstalled. Still doesn't work.
I believe that the problem can be fixed by going into the audio settings in Skype and disabling certain audio controls there. As follows:
In Skype, click on TOOLS, OPTIONS, GENERAL, AUDIO SETTINGS. Uncheck the options for "automatically adjust microphone settings" as well as "automatically adjust speaker settings."
This will keep Skype from cutting off the call.
Posted on Jul 10, 2008
Did you install the PersonoCall software (bundled with Calisto Pro)?
Basically PersonoCall is the one in charge of handling all the VoIP applications.
Posted on Feb 11, 2008
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
Base does not find headset
On page 41 of the user guide link below you'll have the instructions on how the base and the headset can get reacquainted.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Nov 30, 2011 | Plantronics Calisto Pro Series Home Phone...
New user with Blue Parrot B250XT headset. Using it on Skype and PC with iogear bluetooth dongle, all seems to be properly configured. Tested the audio quality from the microphone and it is garbled. ...
It seems that there is a physical problem with the microphone of that headset, It rarely happens but it does, even brand new units sometimes would have defects.
In windows there is a sound recorder feature that you can use so you can try recording your voice from the headset and check if it will be garbled.
you can also test the device on another equipment, Pair it on a mobile phone that is bluetooth capable and try calling or receive a call and check if the same result would appear.
If the same happens for all these steps, if you have just bought the headset you would want to bring it back and ask for a replacement unit or a refund and get a different model.
Hope this helps!
Aug 24, 2011 | VXI Corporation Blueparrott B250-XT...
My voyager pro doesnt work with my skype on iphone.
It may have to do with the settings that are listed on Skype. Because you are using the headset with your phone, it should work with the Skype application, so please check your settings. If it continues to not function correctly, try re-pair or subscribing again.
Below are two links which may help you solve your issues:
Plantronics Voyager Pro User's Guide
Plantronics Voyager Pro Pairing Instructions
Jul 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a logitech Pro 9000. It works completely fine with GChat, but not for Skype. Skype complains " bad internet connection" and the video I transmit is mostly frozen. On the other hand the...
hi freeman319
you might want to try and uninstall the quickcam application. as i've researched skype is having problems with certain cams compatibility. just try and uninstall the quickcam application but not the drivers. with this you may still be able to use the quickcam with other applications.
you can uninstall it through the control panel>add remove programs
also if you are using a headset or separate mic and headset with the video call you would want to disable the mic on the quickcam
go into Device Manager and disable the microphone in the Pro 9000
ofcourse this is just some things you can try but is not guaranteed to solve your issue. please let me know if this works. thanks.
hope this helps
janc30
Feb 11, 2011 | Logitech QuickCam Pro 9000 Web Cam
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
My girlfriend has a Logitech ClearChat Style headset. I recently gave her a Dell E6500 with onboard IDT High Def. Drivers and Windows Vista Business 64. The microphone rarely works (or properly...
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Oct 08, 2009 | Logitech ClearChat Stereo Headset Headset
Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Hope can help
Aug 15, 2009 | Logitech ClearChat Stereo Headset Headset
Lose webcam connection in Skype when using a headset
Have you checked the recording settings in Windows and in Skype? Try changing the default recording device to specifically indicate the device that has your headset plugged. I think the webcam also has a mic and that should not be selected.
Other thing to check is if there is some kind of resource conflict between your USB controller and audio card (use Device Manager).
Jules
Mar 02, 2009 | Logitech Quickcam Chat Webcam
Lands Phones Logo
185 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
