Question about Palm Tungsten E2 Handheld
Palm tungsten E2
Won't turn on, tried soft reset and hard reset
  • 3 more comments
  • franmac Jan 19, 2008
    Finally resorted to opening up the back, disconnecting and reconnecting the battery, then it restarts. However, after charging it overnight, then starting it again in a short time it goes dead again! I have being doing a lot of research and wonder if this is a charger circuit problem that can't be fixed. I don't want to waste money on a new battery.
    Nothing happens once it goes off, it is just dead.
    We tried taking the battery overnight.
    Yes the indicator shows battery as charged.
    The battery charges right away. We have gone through this process at least a dozen times.
    The device goes dead from 15 minutes to an hour after unplugging the battery from the motherboard and reconnecting.
    The battery indicator shows it as charged- is there another way to test it?
    It shows fully charged right away.
    At the initial setup, the battery was still charging when the first hotsync was done. Could this have damaged a circuit or the battery?
    As we have another E2, we are considering taking the battery out of the one thats working and to see whether that resolves the problem, which would mean that is a battery issue or if not, something else.
    President:
  • 1,944 Answers
Does anything happen when you try to turn it on? Does anything respond or light up?
Posted on Jan 19, 2008
  • 1 more comment
  • Damen Wong
    Damen Wong Jan 19, 2008
    You said that you have tried a hard reset and soft reset. Did you try an taking the battery out and leaving it out for at least an hour?
    You say that you managed to charge the battery overnight. Does the battery charging indicator show? Does the battery start charging right away? After the charge, how long does it take for it to go dead again. Sorry for so many questions...
  • Damen Wong
    Thanks for answering all my questions. I suspect that this is a battery problem and getting a new one will solve it.
  • Damen Wong
    How long does it take for the indicator to show that the battery is fully charged?
5 Suggested Answers
  • 89 Answers
SOURCE: Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Posted on Mar 13, 2009
  • 164 Answers
SOURCE: Palm Tungsten E2 stuck on Tap the center of the target
The digitizer part is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
Posted on Jul 25, 2009
SOURCE: The touchscreen on my Palm Tungsten E2 quit
It is a shot, or you can get someone to open it and check the connections....I'm sure you prob can find a replacement on ebay.
Posted on Aug 16, 2009
yungbro29
  • 20 Answers
SOURCE: My Palm Tungsten E2 has an odd problem. While in
take out the battery and put it back in
Posted on May 07, 2010
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
Frozen Blank Screen - soft reset doesn't work.... Do NOT want to do hard reset because all my data will be lost and it is my life line. I am panicking. Please help!
If you back up all your data on your desktop it will be restored with your next hotsync after the hard reset. I recommend the hard reset but if you really don't want to try that they I suggest you try using the free palm chat. Here is the link for that. Be sure to scroll to the bottom of the page and you will see palm Chat. Click on the link that says chat now and follow the prompts. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm Tungsten E2 Handheld
My palm just displays ''Palm Powered'' Tried soft reset
Have you tried a hard reset? Just remember a hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is a link with the directions:
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/solutions/article/42094_en.html#tx
If that doesn't work then try the free palm chat service they offer. Here is a link to that:
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/solutions/article/43473_en.html
Nov 13, 2009 | Palm Tungsten E2 Handheld
The touchscreen on my Palm Tungsten E2 quit working. I had no luck after cleaning the screen, soft reset, or hard reset. Is there anything else I can try or is it shot?
Aug 16, 2009 | Palm Tungsten E2 Handheld
Best regards,
Apr 09, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Feb 27, 2009 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
