Depending on how much hot water is being used and where your temperature is set at this can determine how much hot water you get. You may want to call the manufacturer and they can tell you how to do a volume test. Their number listed is 1-877-817-6750.
You did not specify here so I'm guessing... you have an electric hot water heater.
The problem that happens with them is that the bottom element goes bad. The top one still works so you still have hot water, just not much of it.
Usually when the top element is satisfied it switches to the bottom and heats the rest of the tank.
I think you will find that your only heating the top 1/3 of the tank and that the bottome element needs to be replaced.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
do you know anything about electrical amps or volts or have an elec meter. why did you replace it in the first place? leaking or not enough hot water?
