Question about Philips Magnavox 27MS343S 27" TV
Power issues I actually have a 32" philips model # 32PS60 B121, the tv itself powers on, but the screen and sound do not. What could cause this? I would love to be able to fix it myself, but not if its going to be a disaster. Thanks in advance!
    Scholar:
  • 163 Answers
Audio is linked to the HV side on most CRT chassis.(That means No HV present)... Could be Flyback transformer, H.O.T., Horizontal driver.. Too many things without seeing..
Posted on Jan 29, 2008
Philips 32 inch LCD has colored vertical lines when powered on.
this sounds like a screen fault to me
try grabbing both sides of the tv and giving it a twist
this will either give you more lines or make ur lines go away if this happens u need a new screen
May 15, 2012 | Philips 32PFL3505D 32 in LCD TV
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
May 08, 2011 | Philips 32PW6506 32" TV
I have a tv Philips Model: 32PF9976/12 but image doesn't work only sound
I have the same problem...Only sound nothing else... the screen does not even light up
Feb 25, 2011 | Philips 32PF9976 32 in. HD-Ready LCD...
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
32PF9962 32''
Could be power supply failure
Mar 06, 2018 | Philips 32PF9964 32 in. Television
Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Philips Magnavox 27MS343S 27" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
