Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire ATFB7000ES0...How hard is it to replace control board???
My front loader is stuck on pause. Had a tech come out to determine the control board needed replaced. Needless to say, I had a lot of trouble with the people from the appliance store that was going to fix it and I won't use them now. My husband is thinking about ordering the part and installing it himself. I difficult is it to replace? Any suggestions? The part number we need is #134556600. Thank you so much
  • robert samples May 11, 2010
    lets try this press options and select at the same time for ten seconds lock should come up in the display then press options and select again if it un locks try start or turn the control knob back to start and let me know what happens
    President:
  • 1,314 Answers
Also open and shut the door and hit start again
Posted on Jan 21, 2008
  • robert samples Jan 21, 2008
    make sure the dispenser door is closed all the way as it will set pause too
    if none of this works reply to me and we will run self diag not sure you need a control
The washer will not start. It is stuck in pause.
try unplugging the washer for 5 minutes to reset the board them replug and try again to see if it works
Aug 17, 2014 | Frigidaire Washing Machines
Why is control stuck on pause?
Thank you for allowing me to assist you, Friend.
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Hope this helps! - Z
Frigidaire washing machine model number 137168300a stuck in pause mode
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Jul 12, 2014 | Frigidaire Affinity ATF7000EG
Frigidaire affinity front load washer doesn t start. The washer is in it pauses only.
Hi Victor, I am happy to assist you!
PAUSE commonly indicates that the unit thinks that the door is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the appliance by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit on. If the issue persists, then the washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Sep 15, 2013 | Frigidaire ATF8000F Front Load Washer
My Frigidaire front loader washer is making beeping sound and it wouldn't start.
Hello - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Also try to rotate the drum manually (when it is not in use) and see if you notice a bumping sound as well. If you do, then the drum is not balanced and probably the bearing and pulley system behind the drum will need repairing. You may need to reset the unit at the household circuit breaker for a few minutes to create a hard reset within the unit. Then retry. If it proves to be ineffective contact a professional to move forward accurately. Washer may be experiencing an issue with a faulty door lock, timer, pump or control board not communicating correctly.
Nov 25, 2012 | Frigidaire Washing Machines
Stuck on pause
You either have a bad control board or a bad communication to the timer of the unit and the timer needs to be replaced. If you do not see an alpha-numeric error code displayed I would contact a professional.
Sep 06, 2012 | Frigidaire Affinity ATF7000E Front Load...
My washer is stuck in pause mode and when I checked an the error it was E41 code
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
246 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
