Question about Epson Stylus CX7800 All-In-One InkJet Printer
Paper will not grip to print
When i go to print the paper goes to the right and then never grips or run through to print
you can hear it printing but the paper does not feed through.
Help!
    Scholar:
  • 95 Answers
You need to clean your pick up roller or replace it. I use rubber restorer you can use 91% isopropyl alcohol and a q-tip. Please clean quickly. Don't use anything below this % or you can damage your roller.This should do the job. Let me know if this works.
Posted on Jan 19, 2008
  • Chris Medina Jan 19, 2008
    Do not use alcohol on your printer. You may want to use a little water first before using anything else. Your printer can get damaged if you try using alcohol. Please be very careful.
Epson Photo 1390 leaving the paper grip at the end ...
Use a paper deroller, or strengthen the vinyl backing by adding some sticker on it's back side so it won't curl this much. Packing tape should do it.
Mar 13, 2014 | Office Equipment & Supplies
Scuff/score lines down print plus central grip mark
Possibile solutions
1) Complete cleaning using copressed air or lint free cloth
2) check the cleaning blade on your drum (Round Glass cylinder)3) Change your drum unit
4) replace rollers
Oct 10, 2013 | Canon Pixma Ix6550 A3 Inkjet Printer
The machine does not print. It does not grip the paper. It does however grip the paper to do a Photocopy and it does print out the print align page. what could be the problem
I had a problem with attaching the printer every time I hooked up the USB cable the computer said, " USB divise malfunctioned". I replaced the USB cable and it wooked fine.
Apr 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Will not grip paper
Try this:
Unplug turn off your printer.
unplug its power cable
lift the printer up
put it in an upside down position
shake the printer from left to right for 2 mins.
This troubleshooting will help you find out if there's any foreign object stuck inside the printer.
after that put the printer back to its position, turn it on then try a test print.
If you can also locate the rollers at the back of the printer, try to clean it as well.
Feb 28, 2010 | Epson Stylus Photo R1800 InkJet Printer
We are printing round labels on a 170XiIII plus I have no blackmark so it?s very difficult to calibrate this label When the printjob starts it backfeeds but not far enough to print the complete label I?ve...
No, well not really, the printer requires a area that it is allowed to touch where there is no image being laid, for if it did so allow ink on that area it would go on to the feed rollers and prevent them from gripping you paper.and producing marks on the edges..
but I guess, one may be able.. to place or stick a fake lead edge of paper on your paper, so that your printer may be able to grip your paper,, and you can place your image, or even putting in a custom page size that is ,20 inch extra long incorrect....
although this may work, the printer may or probably will indicate or go into a jam at the end of print due to page length being detected incorrectly, so you couldn't do a run, may get print warnings, and rear exit edge wouldn't print... but it might get you one at a time....give it a go, I'm only trying to explain why we need that edge and the back feed..so we can get a grip :)..hope this helps cheers..
Nov 27, 2009 | Office Equipment & Supplies
Magicolor 2500W keeps faulting when printing reverse side of already printed sheets. Will not pick up sheet from tray
Possibly the paper grip rollers (inside at bottom rear) are waxed and not gripping. Take a small drop of Isopropyl alcohol and wipe the surfaces clean, this usually works.
Oct 06, 2009 | Konica Minolta magicolor 2500W Laser...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
NOT GRIPPING PAPER
Hey,
first clean paper take up roller.
Jun 16, 2008 | Konica Minolta magicolor 2400 Laser...
Printer
hey there mojo
you must align or replace the roller for your printer.
thats why its going to the right. the roller inside is mis-aligned. about the ink, you should clean the printhead.
Apr 08, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Jan 31, 2008 | HP LaserJet 4300n Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
