Question about NexxTech 4-Port Ethernet Broadband Router (N4PROUTER)
When I goto my web browser to install my router it says connection has timed out, I put in http://192.168.1.1/ Tried it so many times I dont know why. Really aggrovating im trying to hook my 360 up for the internet. Any help, please. Thanks in advance.
  • Helliex Jan 21, 2008
    Thanks for the feedback. but, I pinged it and it said it timed out, even after I reseted the router I have no idea whats up.
  • 118 Answers
Follow these steps
1) connect the stright cable from your router to a switch and connect another stright cable to the pc from where you are trying to access the router.
2) if you dont have a switch connect a cross over cable directly to pc from the router ( stright cable some time works)
3) Change the PC Ip address to 192.168.1.150 and subnet mask 255.255.255.0
4) open start programs --> run --> and ping 192.168.1.1 ( u should able to ping)
5) if pinnging is ok .. then connection to router is good
6) now open your browser and type http://192.168.1.1 -- this should work now.
7) if fails -- try resetting the router -- you can see a small hole besides your network ports or somewhere around
8) once reset try agin opening the browser
9) if all else fails probbly the firware in router is corrupt ,, u need to reinstall .. them contact the support site of your router
Good luck
Posted on Jan 19, 2008
  • Mohammed  Rahman
    Mohammed Rahman Jan 24, 2008
    if you are unable to ping probbly this is a connectivity problem
    please check your connecting cables , also check your router manual for its default ip after reset
    if you have a console port to the router try connecting it using console port over com1 using hyperterminal in windows and a rollover cable.
    Hope that would help
    Good Luck
Can 2 wireless routers be connected wirelessly together no cable
In short, the answer is yes.
However both routers need to support what is knows as WDS (Wireless distributed Network)
This allows multiple routers to connect together to extend the signal of a single wireless network.
The steps change from one router to another, but in general you will need to log into one routers web interface (usually by first plugging a hard wire into the router then into your computer. Then open a web browser and put http://192.168.0.1 or 192.168.1.1 in the address bar)
Default username / passwords are usually admin / admin unless you have changed them
Next goto the wireless section and set this first router up with the wireless name and security you wish it to have.
Repeat this on the second router, but this time you will need to goto wireless and look for an option that says "Enable WDS"
Some router have a "Survey" option, this will bring up the wireless network the router can see and allow you to easily select which network you want to connect this router to.
The one big step is to make sure the second router is setup the same as the first, you will need to make sure it is named the EXACT same, and also is using the same wireless password as the first.
In some cases you may want to disable DHCP on the second router, but this may not be necessary, so testing with DHCP on may be your first options.
Test the connection while the routers on are the same floor to start, this will save time going up and down stairs if settings need adjusted.
Also keep in mind wireless signal goes outwards from an antenna, so having one upstairs and one downstairs you may still see low signals, In some cases you can adjust one antenna on each router to lay flat instead of pointing up in the air. This should only be done on one antenna on each router if signal is too weak. It does not always help.
Hope this gets you started, feel free to provide model information for your router(s) if further help is required.
Nov 17, 2014 | Computers & Internet
How do i get my encryption code so i can add another computer to my router
typically you goto your routers web interface through your browser and login with your password (if you didnt set one check your owners manual on the default sometimes its left empty or it could be admin or password)and goto the security page and it should display your key (of course its not going to break it down in plain english for you in form of a passphrase. it will be encrypted) then generally you can use that to get your other computers to connect.
If you dont know the address to your router there are a couple common ones. usually
http://192.168.2.1 or http://192.168.1.1 once in a blue moon http://192.168.254.254 will work or you can goto start---run---cmd and when that calls up type ipconfig /all and find your default network adapter and find default gateway and thats the address or find the IP address and change the last set of #s to a 1
Oct 28, 2009 | NetGear WGR614 Router
Just got dlink router and it appears to be connected right just says no internet connection found and I dont know how to change it It is for a laptop just always says I am offline however it installed and...
Launch your Internet Explore browser goto FILE>Work Offline if that is checked your browser is working Offline mode, just uncheck that, and hit refresh you should be good to go.
-Charlie S.
Jul 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How to implement the security on my router
For linksys routers
In you browser goto: http://192.168.1.1
User: Admin
Password: admin
Goto the Wireless Tab then Security. You can set security on your wireless connection there. Make sure all devices connecting wirelessly use the same security settings too.
Jan 06, 2009 | Computers & Internet
I'm trying to connect my router (2wire) to my Xbox360 but don't know my WEP code.
goto the routers web interface via a connected pc at http://192.168.0.1
and read the wep setting from the wireless configuration page
make sure you dont change the settings as everything else will fail
Jul 14, 2008 | 2wire 2700HG-B Router (2700HGB)
Unable to locate and load drivers???
http://192.168.2.1
to open the routers web interface, use the wizards on the router there is no need to install anything
Jul 12, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Wireless connection
You probably need to goto your routers web page and change the name there.
While you are there it is a good idea to setup at least WEP security if you have not done so already.
To get there, usually, while you are connected, you can look at the properties of your connection, and get your default gateway's IP address.
In a web browser, put this IP number of your default gateway into the browser's address bar and click go. It should load your router's administration web page. If it has a password and you dont know what that is then it is probably the default password.
To get the default password for your router, into Google search for example if you has a linksys router, search Google for "linksys default password" this should bring up the default password for a linksys router. usually a combination of "admin/password".
Once logged into the administration web page, the network name is listed under "SSID".
May 18, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Main PC can't connect but others can!
I had this model of router quite some time ago. I had some bad experiences where when I tried to login to it I was unable to, the web based management interface would not respond (as you have described) . Resetting the device would resolve this I would recommend trying that. Unplug it, wait a few minuets and plug it back in. Then try again to access the management interface. 192.168.1.1 or 192.168.0.1 or whatever via a web browser.
Apr 30, 2008 | Belkin (F5D7633UK4A) Wireless Router
Wireless Connection
You need to goto the routers web page and set it up.
To do that, connect to it and get online with a wired connection.
Now, in your web browser's address bar, put your router's IP address number.
One I saw from belkin was 192.168.2.1 out of the box.
Then click on go and the browser should goto the routers setup page, where you can set your security and wireless network up.
Then, on the computer that is going to be connected wirelessly, setup the wireless network card or adapter and input your network key.
Mar 07, 2008 | Belkin (F5D7230-4) Router (587009)
Challenge please Help! Cant install the driver "code 10 problem with the installation"
you dont need a driver, open your web browser and type in the address bar 192.168.1.254 and you will get into the router and add your settings manually, so long as your router is set up correctly
Nov 05, 2007 | 2wire (1000-400108-001) Router
NexxTech 4-Port Ethernet Broadband Router (N4PROUTER) Logo
76 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
