Question about Crane Pig Humidifier
No water vapor coming out
After I used the humidifier for one month, now there is almost no water vapor coming out. I have check the electrical power supply and washed the water tank, what is the problem? Thanks.
  • Lisa_Bradfor Oct 27, 2008
    I have the same problem. There is vapor, but it is not coming out.
    Problem Solver:
  • 7 Answers
You might need to check either the water level sensor or make sure that there aren't any deposits on the nebulizer. I just posted the following sections from the manual for another problem:
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly. (I scanned a page from the manual that shows how to dismantle and reassemble the sensor: here)
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
I might have the same problem.
my humidifier can still produce water vapor, however the water vapor could not come out through the channel. Eventually, I found that the fan at the base didn't work. It needs extra outside force to start the fan. you might want to check your fan.
Posted on Dec 07, 2008
    New Friend:
Junk and i have a big mouth
Posted on Jan 13, 2016
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
How many watts does the vaporizer have?
They usually are 300 watts... actually not that big of a heater... that is why they use a small chamber to heat the water in and as the stem goes out a bit of water comes in to replace it...
heatman101
Aug 10, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I have this humidifier for past few months but recently, it is not able to pass the vapor from the canal. If I remove the water tank from the platform, I can see that vapour is forming but then it is not...
Sounds like calcium build up pour in vinegar and turn it on till it starts steaming good. Then use an additive in water to keep it from happing again
Nov 24, 2009 | Fujitronic FB-602 Humidifier
This vaporizer is supposed to run for 10 - 12 hours, and mine only runs for about 5. What can I do to change this?
clean out any deposits with white vinigar (soak for a few hours) or use a special cleaner for this ... the deposits will keep the unit from using all the available water .. if it is using all the water in 5 hours then your vaporizer may not be big enough for the area you are trying to humidify ..
Oct 16, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Looking for manual instructions to clean vaporizer with vinegar
all you need is a capful of vinegar mixed into the water and it will clean it like new again
Feb 21, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Runs, but nothing comes out
Check the filters and the fan blade it may have come loose. Do you still hear the motor running? Get me the model number on the unit. Sorry it took so long to get back to you I have been sick the past few months.
Aug 30, 2008 | Bemis 526 300 Humidifier
Humidifier makes a huge noise and no mist
This next part may or may not be relevant.
1835 Ferry Road
Jan 28, 2008 | Crane Cow Humidifier
Doesn't run
When a humidifier doesn't run, it generally means it isn't receiving electrical power or the controls have automatically shut it off. 1) Be sure it's plugged in to an outlet that works and that it's turned on. Check the electrical receptacle for power, using a working lamp, appliance, or voltage tester. 2) If the receptacle seems to be dead, check the circuit breaker or fuse that serves the humidifier's circuit. 3) Check the setting on the humidistat. If it's set lower than the room's relative humidity, the humidifier won't go on; in fact, it may take several hours for the humdistat to respond to the room's changing humidity. 4) Be sure the humidifier's reservoir is full of water. 5) Unplug the humidifier unit. 6) Check the power cord. If necessary, repair the cord. 7) Remove the humidifier's cover panel. 8) Remove the humidistat and check it (as shown below). Replace it if necessary. 9) If it still doesn't work, call an appliance repairperson, take the unit into an appliance repair shop, or replace the unit. To check the humidistat, you?ll need a volt-ohm meter. A humidifier?s fan vaporizes the water in the reservoir and blows the water vapor into the house or room. If you need to check the fan, unplug the humidifier, remove the control panel, and lift the lid. Tighten the fan hub with pliers if it is loose; this should take care of rattles. If the fan doesn?t spin easily when you try to move the blades by hand or if it is still noisy, lubricate the motor bearings with oil. To establish whether power is reaching the humidistat when you know there are no problems with the plug or switches, unplug the humidifier, remove the control panel, and lift the lid. Test it with a volt-ohm meter set to the RX1 scale (or to K[omega symbol] or [omega symbol] resistance on a digital meter). Clip the meter to the humidistat terminals. The meter should jump if you turn the humidistat from high to low. If it doesn?t, you?ll need to replace the humidistat or return it to the manufacturer.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Crane Pig Humidifier Logo
20,871 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
solver2010
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
