Re: DVD won't work when I play it in the DVD player
Read the owner's manual for your DVD player. Some brands (cheaper ones) are particular on the type of DVD to use (i.e. + or - DVD..). Most will NOT play a rewriteable (DVD-RW) disc.
I had a COLBY (WalMart) and it would only read DVD+R discs...
Transfer your .avi movie files onto a USB stick & simply plug them into the Tevion DVD player.
Select the usb button on the remote to activate & choose which film to play from the menu that pops up.
Burn your dvds in a proper way. If you burn your dvds as data dvd, it may not work on certain dvd players. Try different software or different PC to burn your dvds. Check the region code of your dvd player & the dvds burnt. They should match. You may find some region-free players.
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
