Question about Vacuums
Trouble with vacuum suction
I have a Thermax AF vacuum/steam cleaner. I purchased it in 1994. The problem is, when I put the recovery tank in the machine and then put the dome lid on and turn on the vacuum switch there isn't any suction. Normally if you put your hand on the hole in the center of the dome lid you can feel immediate and powerful suction. The hole in the dome lid is where the flexible hose is attached to the unit. If I take out the recovery tank and turn the machine on I can feel the suction through the hole in the bottom where the recovery tank sits. I'm not sure what the actual problem is. The recovery tank seats properly when I put it in and turn it until it drops/locks into place. The dome lid also has both rubber gasket seals so I know that isn't the problem. I did recently have to have the cord replaced. Could the repair person have done something to affect the vaccums suction? Any help would be greatly appreciated. Thanks, Kelli
  • fabricfreak Jan 19, 2008
    Thanks for the reply LizDahl. I did check the hose that attaches to the hold in the center of the dome lid. The problem seems to be with the base unit itself without any attachments on it. You can use the base unit by itself to filter the air in your whole house. You just add the required amount of water to the recovery tank and put the dome lid on and turn the machine on. It's supposed to pull or suck air through the center hole and filter it. That is where the problem lies. It's not creating any suction when I put the recovery tank and lid on. Thanks again. I appreciate the help.
  • sandy mccain
    sandy mccain Jul 12, 2015
    I have the same problem with my thermax AF do you know what is causing the problem
  • 75 Answers
Check and see if there is a blockage.
Posted on Jan 19, 2008
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Won't pick up brown water
Hello! Follow these quick trouble-shooting steps to restore suction to your Hoover F5835900.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Try it out. The cleaner should now have suction. Good luck!
May 31, 2014 | Hoover F5835900 Upright Steam Vacuum
My steam vac doesn't seem to have suction. Help?
(1) Make sure tank lid is sealed to the tank.
(2) Is the filler panel in place on the front of the recovery tank? (Square shaped plastic panel)
(3) Is the tank gasket in place under the hood? There must be a rubber gasket on the round pipe that the recovery tank seals to when it sets down in to the cleaner foot. This connects the vacuum path to the tank.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Looking for a manual Thermax AF
You can call for a replacement manual toll free at 877-248-9191
Sep 11, 2009 | Thermax AF2 Canister Steam Vacuum
I rented a thermax steam cleaner it didnt come with instructions, where is the solution tank
The most logical answer to your question is to phone or stop in at the place you rented the steam cleaner from. They would have the knowledge / responsibility to help you with this...
May 07, 2009 | Vacuums
Hoover SpinScrub
I would almost guarantee the recovery tank is not seated properly. Trust me, I reseated the tank 5-10 times before giving up. I finally decided to give it one more try before forking out the money for another cleaner. I removed the clean water tank, turned the machine on (you could feel the air blowing out the sides on the bottom). With the machine still running, I unclipped the recovery tank and lifted it up (yes, you can do this, and it creates a very loud air thrust, but don't be scared), then I SLAMMED it back down into the seat and immediately I could tell the difference. The air stopped blowing from underneath and I could tell I had suction once again. I turned it off, put the clean water tank back on, and it worked like a charm. Trust me, you may be convinced that the recovery tank is seated ain't! Hope this helps!
Mar 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Lost suction, gasket problem
This is a great basic steam cleaner. I have not heard of repeated problems of this type. The gasket is called a standpipe gasket. I would try to use a non-permanent sealant such as RTV silicone to adhear the gasket, eventually if this needed service you will want the gasket to be able to be removed.
Feb 02, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
156 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
