Question about Sanyo DS24425 24" TV
No click. memorex mt2024 no click,replaced str sme thing,power supply component are testing ok.any hints, thank you
It is in a stanby, wen power it runs to 2-3 seconds then it back to sanby
Posted on Jan 30, 2008
LG tv str w6754 glows and short. power supply is not working?
Replace that STR. Before replacing, check all the related component/s at the SMPS section [HOT] side. any one damaged component will make the replaced STR to fail. If you wish to get some details; check the site linked here. Pull up older posts.
SMPS Circuit diagrams [STRW6754] of many popular brand TVs and other devices are given.
Search the site by type in the "BRAND NAME" or the STR number; of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | LG Televison & Video
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
What is the Universal Remote code for a 20in Memorex TV model MT2024?
Hello
Memorex Tv codes with GE-RM-24961 model remote control are:
.000 001 004 009 049 051 135
OK.
Jul 06, 2011 | Memorex Televison & Video
NO POWER. CORD TESTED OK AND IVE ALREADY CHANGED THE FUSE BUT STILL NO POWER...
Why did you change the fuse? If it was blown, then power supply has failed. Here is your schematic. The power supply is on page 14.
http://elektrotanya.com/behringer_ub-2222fx-pro.pdf/download.html
Scroll down the page at the site to the "Get Manual" Click on that to download the schematic. When working on line operated supplies use an isolation transformer for personal safety. The regulator chip IC2 has probably failed but test before changing. HINT: When restoring the supply, put a 60 watt light bulb in series with the hot power lead to act as a resetable fuse... saves fuses and also other components if all the bad parts haven't been weeded out.
May 11, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
I have a Hi-Fi stereo with with turntable, two cassettes, three cd's two jacks for audio, one for MP3, and one for earphone the brand is memorex the audio has quit the hi-fi was built sept 2006 how do...
Ok, well whenever any Amplifiers Output suddenly quits, it is usually only one of two things, or possibly both, and they are The main Power Supply Unit, has faulted. The Main Audio Amplifier has failed, or as said, both.
Replacement, of the faulty component is the only real alternative.
If you wish to DIY, then you will need a service manual, for your exact make and model. Tools, Soldering Iron, Multi-meter, De-soldering Pump.
If it turns out to be the PSU, then this is a pretty simple drop in replacement, however IF it is the Audio Output Module, then this must be De-soldered from the PCB, and the new one re-soldered back in.pretty simple if done slowly and carefully.
If you do not wish to DIY, then i recommend that you obtain a "Quote" for any repairs from an authorised service center for Memorex. http://www.memorex.com/en-us/ Contact them and ask for a referral to a service center that they recommend clos by where you live. it may even be best if they accept, to return it to them for repair?
Dec 15, 2010 | Audio Players & Recorders
Dear Sir, I'm Bangladeshi Tv Techanician, Sony tv
Hello
Before replacing the STR, have you checked all the components related to it? When STR burns out some of the nearby components, such as zener diodes and other resistors will also get damaged. You just replace the components, especially, zener diodes, in case it does not show any fault, replace it. Connect a 100W filament type bulb in seris with the power supply, and switch on the set. This will reduce the power concumton at the begining, and we can check its heat effect also, after all are ok we can connect directly. Check the smoothing capacitor at the secondary 130VDC. Replace it also. If you need furthermore assistance, feel free to contact me through Fixya. I'm an Indian, residing at Trivandrum, the capital city of Kerala State.
Dec 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Greenish color whole screen
THERE IS APROBLEM IN VIDEO SECTION.OR CRT TUBE .REPLACED CRT BASE AND GREEN CATODE TRANSITOR OR WHOLE BASE IT WILL WORK OK
May 20, 2008 | Memorex MT201224 20" TV
Memorex mt2024
try 1234, 0000, 1111, 2222, etc
Feb 24, 2008 | Memorex MT201224 20" TV
Memorex MT2024 programing
THE ONLY SOLUTION IS TO ORDER A REMOTE FROM MEMOREX. I HAVE TRIED FOUR DIFFERENT UNIVERSAL REMOTES AND CONTACTED THE MFGS HELP-LINES WITH ZERO SUCCESS. I FINALLY GOT SOMEONE AT MEMOREX TO ADMIT THAT THEIR REMOTE IS THE ONLY ONE THAT WILL WORK ON THIS (MT2024) SET. "$88.OO".--- WHAT A DEAL FOR A NEW TV! IF YOU BREAK OR LOSE THE REMOTE, THE FRUSTRATION QUICKLY BUILDS AND ADDS UP TO MORE THAN $88.00
Sep 02, 2007 | Memorex MT2206 TV
19 inch portable TV Memorex
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Dec 31, 2006 | Memorex MLT2022 20 in. EDTV-Ready LCD...
Sanyo DS24425 24" TV Logo
95 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
