Question about Sanyo DS24425 24" TV
Wide white horizontal bar
Rca f25432 ctc203ad have one and half inch wide horizontal bar,vert ic and surounding components tested in good shape,do some one knows this problem,thank you/
    Problem Solver:
  • 5 Answers
Do actual replacement of all electrolytic capacitor surrounding from the vertical ic.
Posted on Jan 19, 2008
Horizontal ine in CRT tv
Failure of the horzontal linerity coil, possible dry soldering on the board of the components- resistors and capcitors- in the horizontal coil circuit . Also failure of the deflection coil- YOKE- in the crt. So check the coils and the circuit around this section as the rest of circuit seems OK.
Apr 06, 2011 | Televison & Video
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Convergence problem with old rca 46 in rear projection TV
you will need to have a shop re converge it or order a new convergence board.
Nov 17, 2008 | RCA P46924 46" Rear Projection Television
Picture in narrow line on 35" Tube set
The problem you are describing is called loss of verticle deflection. You will find this will require diagnosis and there is no simple answer to this repair. Most likely there will be either bad electrolytic caps or bad vert. output IC in the vert. circuit.
Mar 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
NEED ASSISTANCE
Here is the infomation you need...
Feb 16, 2008 | RCA F25432 25" TV
Rca f25432 have half screen.
If you are experiencing the vertical issues, I would check the tuner for poorly solder aroound the ground shield if the tuner is the one integrated on the main board.
Check this sity for the schematic diagram as well: //http://www.eserviceinfo.com/download.php?fileid=31473
Good Luck.
Jan 25, 2008 | Sanyo DS24425 24" TV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
RCA Model number F25432
the horizontal output transistor my be shorted out, or the flyback transformer my be open? Have you unsoldered and tested? If you are not a technician, or have no experience I would not suggest to work on the tv yourself. good luck, Mike
Nov 27, 2006 | RCA F25432 25" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sanyo DS24425 24" TV Logo
66 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
