Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont start - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • vianored Apr 09, 2009
    My mp3 is saying recovery mode and it says reload firmware
I had the same problem for about a year. When the clothes are loaded, the lid closed and the water filled to the desired level, it would not start automatically. For months my whole household had to bang or slam the lid down for it to start. I finally called my brother who repairs appliances and lives outside of the US. He told me to check the two screws on each side of the lid. If they were loose, tighten them with a Philips screwdriver. I did the right ones first, but when I went to tighten the left ones I discovered that one of the screws were missing. He then told me that the reason for my problem was that the missing screw is causing the hinge not to stike with the switch or something of that nature. Anyway, I replaced the missing screw and put a wash in as adviced. The machine started up fine when filled and is working perfectly. And to think that I was at wits end: about to call a repair service who would have put that screw back in and charged me $200.00!! I hope this helps.
Posted on Jun 13, 2008
Thanks for the help it solved my problem !!
I did not have a screw problem on the door but I did have a switch problem on the door.
When I opened the machine I noticed that the arm on the bracket had bent forward from constant opening and closing the door. With a crew driver I bent back the arm back some so that it could trigger the switch and start the machine.
Although it wasn’t the same exact problem your entree led me in the right direction.
Thanks so much.
Posted on Jan 25, 2009
  • 770 Answers
Does it fill ?? agitate?? spin?? wont do anything??
Posted on Jan 26, 2008
Polo 2001 1.9 ssdi wont start fuelfilter/belt/fuelpump all done ecu was wet dried out wont start
Have you run basic tests? Spark at plugs? Correct fuel pressure at key on? Compression?
Mar 27, 2016 | Cars & Trucks
Why wont my 2005 ba ford falcon start?
Have you changed the fuel filter?. Have a fully charged battery if the cranking voltage drops below 10 volts the computer can't work and it wont start.
Aug 11, 2014 | 2005 Ford Falcon
Won't start won't turn over or do nothing put new battery still wont turn over wont start
No one can help you much if they do not know what year etc. your bike is. WHAT DTCs are set??
May 04, 2014 | Harley Davidson FLHX Street Glide...
Wont start, service start system
blow fuse
check all fuses first with a meter.
what engine?
what transmissin, A/t or M/T
do you mean wont crank
or
cranks fast and robust but will not start
no a/t car starts if not cranked.
Mar 19, 2014 | 2010 Suzuki Kizashi
Wont start, but it will turn over
this doesnt make any sense wont start but it will turn over then u say it starts but wont kick over??? hmmmmm do u have gas in it?
Jan 05, 2014 | Cars & Trucks
2005 camry starts fine then wont start jump start okay for a day a month maybe then wont start
This behaviour is typical of worn starter motor main contacts, at the bottom of the starter solenoid.
Feb 25, 2013 | 2005 Toyota Camry LE
Wont start
if i drive my bronco to work shut it off it wont start sounds like it has a dead battery if i let it sit for an hour it will start back up can you tell me if you know what it is
Dec 15, 2008 | 1989 Ford Bronco
WONT START
check the ignitionswitch or the main relay
Sep 26, 2008 | 1994 Honda Accord
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
