Question about Zenith Z50PX2D 50 in. Plasma HDTV
Installing my plasma tv
I have digital cable, and I just purchased a plasma TV, do I need any special hook up devices or cables
  • 3 Answers
You will want to use an HDMI connection for you cable. Check your cable box, it will be marked HDMI and probably have a cover snapped over it. Depending on the available inputs on your set and outputs on your other devices you may have to use component connections for your dvd player. Those will be marked "Y, Pr, and Pb" and will be RCA type connectors. (like the old stereo speaker hook ups). Check you cable box for an optical audio output and your surround sound unit if any or TV for optical audio inputs. They will be marked appropriately and may have some type of cover over them. Use that for your sound if you can. All of these cables can be obtained at your local electronics store or Walmart. You will want to measure all of your distances to insure the cables you buy are long enough to make the connections. Also be very careful of the optical cable. Don't kink it or fold it, they can be damaged internally and are fairly expensive. Lastly make sure all of your equipment is plugged into a good Surge suppressor not just an ordinary plug strip. A $20 investment for power conditioning can save you a lot of headaches down the road. I hope this helps you, Good Luck.
Posted on Jan 20, 2008
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
Tv only goes to channel 135
In order to get channel 514, you will need to get the digital box/converter from the service privider. LCD's or plasmas are not capable of decoding those channels.
Jan 29, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
THE VOLUME DOESN'T WORK ON MY SAMSUNG PLASMA TV! ONLY WHEN IT'S ON TV! WHEN I PUSH THE SOURCE BUTTON AND CHANGE IT TO DVD THE VOLUME WORKS JUST FINE!
if you are using some device like digital box you should try to check the cables connecting your unit specially the audio cables.
Jul 05, 2011 | Televison & Video
Do I need a special cord to record from digital tv
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Oct 02, 2010 | TruTech TT1620 DVD Recorder
Where is the cable hook up on the tv?
This plasma is only a monitor meaning they do not have a tuner, so it doesn't have a cable hook up. If you want to receive over the air channels, if you live in the USA, you will need a digital converter decoder or if you have cable/satellite suscription you will need a cable/satellite decoder box to receive the channels.
The way to connect any of the mentioned devices to your plasma is to use the yellow, red and white cables to the input of the TV and select input 1 or video 1.
If you live where you can still receive over the air analog channels, a VHS should work.
Let me know if you require further assistance.
Aug 13, 2010 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Just purchased 50" Samsung plasma tv. We can only get black & white on the tv, but if we put a dvd in, it is in color....could it be our cable hook-up or what?
could be your cable box or even the cable used to hokk it to the cable box, run the cable straight from the wall and see if it still happens
Dec 27, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Problem connecting cable wires for Sony PFM-42B2 42 in. Plasma TV
I have this screen and my version does not include audio - I need to connect to an external amplifier, in my case my home theater.
Nov 18, 2008 | Sony PFM-42B2 42 in. Plasma HDTV
Problemw with digital TV signal using an arieal
I recently purchased an ilo 32 inch tv and am having problems because when I first purchased it I had it connected to a cable box now I no longer have the cable box just the cable and am unable to hook it up because the connecter does not hook up to a regular cable cord is there a special connection that hooks it up directly to the cable cord? I read in the manual something about a F-type connector where can I get one?
Mar 28, 2008 | Televison & Video
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
