Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Fills with water but wont start
For a while i have had to push the door down and it would start but now wont do anything after filling with water and solution?
  • 2,039 Answers
Probably the switch is broken push the switch down with a pen or something that gonna fit in if it start change the switch or bypass it by bypassing it it will run even if the cover open cheers
Posted on Jan 19, 2008
Maytag dependable care plus will fill up with water but wont start cycle
sounds like you have a bad lid switch part 3949247 and it's around 50 dollars.open the lid,look at the right side,you'll see a hole,stick a screw driver into the hole and push down easy with the machine set on spin,if it doesn't spin and when you push up and down on the switch with the screw driver the lid switch is bad.watch video
http://www.youtube.com/watch?v=V5aW9WkTFhE
Mar 29, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Front load frigidaire washer wont do anything but fill with water and drain and the door wont lock
Hello Cheryl Watson - Not quite sure I understand the issue. If the unit is filling with water and draining immediately, with no tub rotation or movement, more than likely there is a failure with the motor circuit (i.e. the motor, motor control board, belt, wiring or door switch). Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 04, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Icmaker
Is the Ice Full metal bail (connected to switch) hanging down (Icemaker ON), straight out (off) or missing? If straight out, push down, if Missing, find and reattach or manually flip the switch that the bail connected to (near light), close door and see if it kicks on.
Another possibility is the entire feed, valve and fill piping froze and is packed with ice. Use caution here...
Fill a large bowl that will fit in the cubetray with boiling water and carefully insert it into its location, Flip the switch up (straight out) close the door, set kitchen timer for 30 min and check it then by removing bowl , flipping bail down and closing door. It will take 30 sec or so to start filling.
If all that gets you no joy, replace the fill valve solenoid
Jan 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
Washer does not fill at all
Have you checked the filter just inside the water hoses. You just turn off the water and unfastenent he hoses from the machine and you will find a little filter. It may be clogged with lint, sand, etc.
Jul 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
