The game does not provide an option to delete save files and the recommended method is to simply start a new game and overwrite the existing files
Saying that, you can delete save files by purposely corrupting the files (by, say, turning off the DS as the game is saving), although there is a small element of risk as you can end up with a partially corrupted save that you can neither load from or save to
Hi,i dont think you can actually DELETE previous users but you can OVERWRITE them
to do this you just start a new game as normal and when you get the first chance to save your progress,which is at the drawbridge of the village,go into the save options and you can overwrite one of the previous saved games JonnieC
Please let me know how you get on or if you need any further help
[email protected]
Simply select New Game from the menu and overwrite the existing save file (this is the recommended method)
The game does not offer an option to delete save files (although it is possible using the arguably risky method of purposely corrupting the file by, say, turning off the DS as it saves)
The game doesn't have an option to erase save files
The best method is to merely overwrite the save files
It is possible to "erase" a save file by corrupting it (such as turning off the DS as it saves), but this should, of course, only be done at your own risk
The game should, of course, overwrite existing saves without problem
While the game does have a few set save points, the best way to save (which can be done at any time) is to use the Save option in the trunk (some players forget about this)
If you save into a save slot doing this and it's not there when you next restart the game, then something is wrong
If you purchased the game "second hand" on eBay, then you may have ended up with a pirated copy (these have caused various problems for players including stopping during the game)
The game doesn't have an option to delete the save files
If you are confident that saving just isn't working and you're unable to return the game for replacement or refund, one drastic course of action may be to corrupt the save (by quickly turning off the DS while it saves), thus causing the game to say the save is corrupted and make a new save file ... naturally, this should only be done as a last resort
i had this problem and then I realised that when you click save, you then need to select which file you want to save (generally in your own name) it will then pop up with "progress saved" - simply selecting save is not enough
Load a save file you want to delete. Hit save on the same slot, and then eject the game while it's saving. Load the game again, it'll give you a message saying it corrupted a file and was deleted. Do the same for the remaining files, this doesn't erase your own file.
