Question about RCA Lyra RD2011 MP3 Player
How do i get music on the RCA Lyra
I have it connected to my computer with the usb cable and then i click update and the computer never finds the stupid thing. What am i doing wrong? uuuuggg
0 characters
1 Points
MP 3 player is frozen - removing battery doesn't help
You will be able to restore the functionality of you Lyra after you reinstall the firmware you can download from the manufacturers website. This is a very common problem for mp3 players.
Here are the instructions once you have downloaded the file.
We highly recommend you do not connect your player to the computer until Step 3.
  1. Locate the downloaded RD2010/11/12/15 upgrade file and double click it.
  2. Following the onscreen instructions, allow the program to completely install all USB drivers (Windows 98SE and Windows ME) as well as the upgrade program and firmware. You may be required to reboot once the install is complete.
  3. Connect your RD2010, RD2011, RD2012, RD2015 to the PC using the USB cable.
  4. From the “Start” menu, select “Programs” > “Lyra™ Personal Audio Player” > “RD2010, RD2011, RD2012, RD2015” > “Update Device.”
  5. After the program is finished searching for the device, drivers and new hardware may be detected and installed. Then the “Update Lyra™ (RD2010, RD2011, RD2012, RD2015) Device” box will pop up with current version and new version (1.51) of firmware shown.
  6. Press “Start” to update the firmware of your Lyra™ RD2010, RD2011, RD2012, RD2015. Depending on your existing firmware version, the Upgrader might show an option for formatting the device. Click “Yes” to continue.
  7. When the update is complete, click “Close.” If present, use the Windows system tray icon to safely disconnect the Lyra™ RD2010, RD2011, RD2012, RD2015 and unplug it from the USB cable.
    Your update is now complete.
I hope that helps.
Nov 24, 2009 | RCA Lyra RD2010 MP3 Player
go to the website and download the new software for your player..
Mar 26, 2009 | RCA Lyra RD2765 MP3 Player
Lyra rca mc4002a
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpg, the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 01, 2008 | RCA OPAL M4001 MP3 Player
Seperating musci by files
Work with your Lyra. I use the alphabet to keep my songs in the right order.
1. Connect your Lyra MP3 player to your computer using the proper cable, and click on your desktop to open "My Computer".
2. Click to open the drive labeled "Lyra".
3. Right-click on the song name, and choose "Properties" from the menu.
4. Go to the "Details" tab (I believe)
5. Highlight the name and change it. For Example: If I want the song "We Will Rock You" to be my first song, I name it "aaaWe Will Rock You". I want the next song to be "We Are The Champions" so I call it "aabWe Are The Champions"
6. Some songs have security issues and will not allow you to change their names. Then you are out of luck.
I hope this helps.
Dec 31, 2007 | RCA RD1076 MP3 Player
Have rca lyra mp3 , but on cd with it
If you have Windows XP you need to download Musicmatch Jukebox in order to transfer music. Google it. You will probably have to pay for it. However Musicmatch Jukebox does not work with Windows Vista. If you have Vista, you can use Windows Media Player to transfer music to your Lyra. The Media Player automatically comes with Windows Vista OS. Of course, you need to connect your Lyra to your computer using the proper USB cable, so your computer must have a USB port.
Dec 10, 2007 | RCA RD1076 MP3 Player
Neeed help
Try a format, Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Sep 17, 2007 | Thomson Lyra PDP2860 Digital Media Player
RCA Lyra MC5102A
connect lyra to computer
go to my computer on your start menu
lyra will show up on other devices or portable devices
double click on the lyra icon
this will bring up another lyra icon right click on that
go down to the option format and select that
you will lose all of your music
solved my problem two hours after it started
Aug 31, 2007 | RCA Lyra RD2765 MP3 Player
My rca lyra rd1080b
this is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
Apr 22, 2007 | RCA Lyra RD1080 MP3 Player
Failed to Load Files
I was able to access the play list using Windows Media Player. I was trying to get the computer to recognize the player, and it wouldn't do it. I even downloaded the Lyra Personal Audio Player updater... that didn't work or recognize the player.
Try the programs that are on your computer for playing MP3's.
Jun 12, 2006 | RCA Lyra RD2854 40 GB MP3 Player
RCA Lyra RD2011 MP3 Player Logo
21 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
