Question about Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Tamron 28-300 loose lens parts
Can I take this apart and attempt to fix it myself? Tamron wants $100 to send it in and fix it, thus its cheaper to buy a new one whihc I have done. Figured I could try to take apart the old one and try to fix it, if I fail I'm not really out anything. Thanks
  • 1 more comment
  • fishsqueezr Jan 19, 2008
    there is small, dime sized lens that came out, and inside i can see a larger lens set in a small platform that moves from side to side. I can't figure out how to get inside the canister to get at the latter lens.
  • fishsqueezr Jan 21, 2008
    Somewhat helpful. I took the whole thing apart from the rear and at the end realized I could get to 1 of the 2 pieces I needed to fix from the front of the lens by removing 3 small screws hidden under the rubber gasket around the front lens. Would have saved me quite a bit of time. I did need to go through the rear and disconnect the motor electonics (very easy) to remount the dime-sized lens mentioned above however. I continued dismantling past this though thinking I could not get to anything from the front.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    What needs repaired with the lens?
  • 667 Answers
The way in to this lens is from the rear. You'll need to remove the trim ring inside the mount and free the electronic connector from the mount ring before you remove the mount ring itself.
Posted on Jan 19, 2008
I have seen 2mm wide fungal spot just inside first front element of Tamron 150 - 600 mm lens. Can any one tell me how to remove it?
You'll need to send it to a lens repair service. Do not attempt to disassemble the lens yourself; you'll only make the problem worse and may damage the lens beyond repair.
Apr 09, 2018 | Tamron Cameras
My friend dropped her Tamron 28-75mm 2.8 lenses from a cliff to the salt water. I rescued it and as we know, the electronic part does not work anymore but the mechanic does. I toke all the parts apart and...
This lens is probably ruined anyway, before you began your DIY attempts. Take it to a repair facility, but be prepared for a hefty bill, even if they will countenance attempting to repair it.
May 10, 2017 | Tamron 28-75 F2.8 XR AF Lens
My lens no longer auto focuses and is continually hunting the image, I have confirmed it is a lens problem by changing camera and lenses and it is only the tamron which is a problem
Unfortunately this is a risk when you use third-party lenses. The camera manufacturer's lens to body protocols are not open source nor do they licence the technology to alternative suppliers, so all that companies like Tamron can do is to try and reverse engineer the system.
You only have two possible fixes:-
1. Replace the lens with a Sony Alpha model; or
2. Contact Tamron to see whether they offer an update service for your lens.
The latter is certainly possible with some brands/models, but the costs have historically varied between "you pay just the shipping and handling" right up to "it's cheaper to buy a new lens".
So you either pay a high price for Sony Alpha genuine lenses which are guaranteed to always work with Sony Alpha bodies and firmware updates, or pay repeatedly for third party lenses. "You pays your money and you takes your choice".
Jun 16, 2011 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
I dropped my camera, with lens attached, and although the body works fine, the lens will not focus. Take the lens off the camera, and look into the back of it (the lens), and there is a round, black,...
Wow I appreciate your spirit but this is probably a loosing battle. Even if there was a repair manual you would still need the tools. This is a $150.00 - $200.00 lens. I'd probably elect to buy a new one and sell the broken one on EBAY for parts or try to take it apart just to satisfy my curiosity. Sounds like you like adventure.
Good Luck!
Feb 24, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Drop my Nikon D100 camera with a Tamron AF 75-300mm LD lens...lens will not extend, stuck on 200mm. If is worth repair, or can I repair it myself?
First question "is it worth repairing" if it were mine I'd look to see what a new one is worth then divide that in half (cause that's what you might be able to buy a used one for) then figure about $120.00 for cleaning lubricating and adjusting the your lens. With your lens you know what you have, buying used might need the service. you are the one to decide. As for the second question "can I repair it myself" short answer no. If you have to ask if you can repair it then you don't have the necessary tools and general knowledge of how to dismantle and reassemble the lens (and have it work when finished). The lens took a hit and most likely set the inner and outer lens barrels out of alignment causing the inner barrel to slip out of its seal and or focusing gear and hang things up forcing it will break parts causing more repair costs. All else fails get an estimate before repair. Been there with a lens myself and after a couple a months without bit the bullet and had it repaired. Cheers best of luck
Jan 28, 2011 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
24mm1:2auto wide angle the lens is coming apart
With all due respect, your lens is not worth repairing unless you are already experienced in making lens repairs, and from your question you clearly aren't. The Vivitar 24mm f2 and the f2.8 versions are not the easiest of lenses to start learning on. The fault is either due to wear (new spares no longer available, used spares in very short supply) or one or more loose/missing internal fasteners (probably the focussing ring limiters), but investigating and accurately fixing the cause is not cost effective.
You can buy a replacement on auction websites for anywhere between £30 and £80, and for about £20 to £60 less if you're prepared to accept the f2.8 version which is one stop slower at maximum aperture. Even at the higher price you'll find that it's cheaper than having your lens professionally fixed (or even for paying for a diagnostic strip-down only to be told it's irreparable). However, you can offset some of the cost by selling your lens in it's current condition and honestly described as being for spares or repair. As it's the faster f2 model it's always in demand and will appeal to those who have the skills to restore it to working condition. Another one to search for (and much easier to find) is the excellent Tamron 24mm f2.5 which typically sells for around £20 to £35, although you may have to spend more to obtain the correct interchangeable Adaptall-2 mount for your camera (but you can get most of that back when you sell the unwanted mount supplied with the lens). As the maximum aperture is f2.5 the lens is only about a half a stop slower than yours.
I hope that my reply has helped, if so please rate my answer.
Feb 22, 2010 | Vivitar Cameras
Loose lens
Hi, I have the same problem with the same lens. Did you fix it yet? Mine is the Tamron Aspherical LD XR Di II SP 17-50 f2.8. I'm thinking about getting the screwdrivers to it.
Nov 28, 2009 | Cameras
Have a two month old 18-270 Tamron lens. Used it a
If it's only two months old then it's still under the manufacturer's warranty so send it back to Tamron. I can't tell you where to send it as you haven't said which country you're in. Tamron value their reputation and usually provide excellent after-sales care.
If you're in the UK you additionally have Sale of Goods Act protection for up to six years in England and Wales and five years in Scotland. Either way, the Act allows you to demand a full refund or replacement from the retailer; I'd suggest a refund as bad lenses often come in batches and a different supplier is less likely to have one from the same production batch.
Note that any attempt to fix the lens other than by normal use of the lens and camera controls may completely remove your warranty benefits or consumer protection.
Oct 26, 2009 | Cameras
Lens jams when extending or retracting
This is either due to a cracked internal roller or a cracked/broken internal cam. The lens will have to be sent to Tamron for repair.
Apr 12, 2009 | Tamron 28-300mm f/3.5-6.3 Minolta Mount...
Lens will not change range. Something came loose inside
Are you trying to turn the barrel of the lens when it is in the Macro Button on ?
Sep 05, 2008 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Tamron 28-300mm f/3.5-6.3 DI XR for Canon Logo
1,433 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
