Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
Anonymous Posted on Dec 08, 2009
Put in a new bulb and still have colored spots on screen?
Anonymous
Level 3:
  • Panasonic Master 5,138 Answers
  • Posted on Dec 08, 2009
Anonymous
Panasonic Master
Level 3:
Answers
5138
Questions
5
Helped
1004515
Points
13534
Light Engine, Go to this website They List all the Parts you need for this TV as well as Service Manual you can download it for Free Encompass Parts or Call 1-800-638-3328
To remove a black spot on a old sharp model TV?
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years,
and the price is USD190
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
1helpful
White spots on screen on dell m209x projector how do i fix ?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
Brown spots
brown spot on the screen
the dust on the top of the LCD panels,
need to clean the LCD panels
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp.
Use a clean piece of toilet tissue when installing the new lamp to eliminate the above.
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
Jerry China
Skype: lampdeng.com
Big yellow spot on the screen after we put in new bulb
hi, you have a issue with something called a optical block, its basically where the image is colored, that piece needs to be replaced
2helpful
COLORED SPOTS ON SCREEN
Bad Light Engine. If still under warranty Get it Fix Now if not call UED for rebuilt one ,you can also CK on E-Bay in Parts Electronics. 1-800-648-6657 This part is not Cheap!
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
2helpful
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
2helpful
Movie mate 30 brojecting blue spots on screen
it's the light polarizer on the blue lcd panel. it's fried due to excessive dust and heat. unfortunately you'll have to replace the optical engine.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
