Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
2006 Mazda 6
My grandfather cleaned the erosion off my battery yesterday. After doing so I noticed today that my Automatic push wouldn't work for my window's Driver/Passenger. Also my Interior Lights on the roof won't come on when my doors open and the switch is on Door. Any clues to why my car could be doing this????
  • Anonymous Nov 25, 2008
    Courtesy lights won't come after changing bulb in side door.
  • 26 Answers
I agree with pierre. if he connected the power wire first, may have blown a fuse. those components are usuallu on the interior light fuse or courtesy fuse.
Posted on May 09, 2008
  • 2,039 Answers
Well i guest our gradpa blown a fuses i mean not is ours check interior light fuse very easy get a test light ground 1 end to metal of car good ground on the fuse there 2 little metal hole car running and light on with test light touch each side of the fuse good fuse gonna light up bad one only 1 side gonna light up you can always remove 1 by 1 be carefull to put the fuse back were day belong hope it will fix the problem cheers
Posted on Jan 19, 2008
Hello I have a 2006 Mazdaspeed 6 and my buttons on the car are not working but if I use the smart card to unlock/lock it works. And the batteries have been changed. What can I do. Pls help
You must have disconnected your battery for something or your battery died? But to fix, go to all the other 3 windows and push them down until you hear it click twice, then your driver side controls should work again..
Aug 23, 2013 | Cars & Trucks
On my 2006 Elantra, yesterday I noticed one headlight out. Today, only the high beams work, the tail lights are out, and the cruise control doesn't work. Has anyone else had this problem?
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here:
Mar 12, 2013 | Cars & Trucks
What could be causing my 2005 mazda 6 to keep dying while I am driving it?
Have the codes read with a scan tool. Most auto parts stores will do it free.
Jul 01, 2017 | 2005 Mazda 6
I have a 2006 Dodge Charger. Went out yesterday, car started fine. Got home and stooped at my mailbox, when I went to start the car it wouldn't start. I did notice the lights on the dash would go dim...
I'd start with a battery first. Sounds like the battery has 1 or more dead cells in it. the battery may have all the volts you could want but if it doesn't have the proper amperage it won't crank the motor. You can have the battery load tested for free at Auto Zone or Advance Auto. A simple down and dirty test would be to disconnect the Positive cable and jump the vehicle by connecting directly to that and a good ground on the block. The motor should turn over as long as the vehicle you use as a jump has the proper amperage in it's battery. If the vehicle starts then it is the battery, if it doesn't then you need to look at the starter and other components.
Jun 26, 2011 | 2006 Dodge Charger
2006 mazda 6 just fitted a new battery now one touch power windows dont work
I had the same thing happen when I replaced my battery on my 2006 mazda 6. The program has to be re-programed and it is very simple. Simply push the window button down until window rolls all the way down, then pull up and roll window back up, but dont let go fo the window button for 3-5 seconds after window rolls back up all the way. This resets the program. Do it to both driver and passender side windows and do it with the key in the on position, but not with the motor started. Hope this helps ya
Aug 12, 2010 | 2006 Mazda 6
Tried changing out the battery in my 2006 mazda 6. Now it locked up. I can't even push it.
Is it the battery charging you are asking ? if so remove and change the acid and recharge for 12 hours.
Jun 28, 2010 | 2006 Mazda 6
1997 sable with 12000 miles electrical problems
earth cable from body to engine and battery to chassis ,clean the connections and fit an additional cable ,also clean and grease the battery terminal
Jan 25, 2010 | 1997 Mercury Sable
03 Matrix completely dead!
check main fuses, circuit breaker check, check and clean terminals, check for corrosion in battery cables
Sep 17, 2009 | 2006 Toyota Matrix
'05 mazda 6 will not start with new battery
Make sure connection for thick red wire going to starter is good if you had that much corrosion.
Jul 25, 2009 | 2006 Mazda 6
Car Audio & Video Logo
184 people viewed this question
Top XO Vision Car Audio & Video Experts
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
