Question about Kenmore 20722
Won't spin my kenmore washing machine is a top load. it fills and empties ok but doesn't want to spin if you lighten the load it will spin sometimes
  • 943 Answers
Hi thanks for the question the problem you are having is with the clutch located on the transmission replace the clutch
Posted on Sep 28, 2008
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Kenmore top loading washing machine manual for 110. Machine does not activate pump to empty water. Also, spin cycle does not work. Machine will fill up OK and aggitate OK.
Check the lid switch for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2009 | Kenmore Washing Machines
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
My Washer machine fill up dosenl' spin
I think the problem is a faulty inlet valve that needs replacing. Hope this helps.
Jan 20, 2009 | Kenmore 24932 Top Load Washer
Kenmore washer 110 20912 990 will not spin or empty
sounds like perhaps you dissconnected the door latch assy,and never reconnected??? hte unit will not spin/drain with the door latch not making contact
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Does not spin
There is a coupling that connects the motor to the transmission it about a 5 dollar part. Turn the washer on it's side and look at the motor in between you will see the coupling.
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washer
Does washer spin without any clothes or water, try 'spin' only. If no, then u might have a loose connection to the motor. After u disconnect from the wall socket, see behind to see if all connections are ok. Do not over-load your machine, it could trip a switch which will stall things. Suggestions...
May 01, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
