Fax Number Issue?
I have no phone line, only cell phone, and just bought an all in one Laser printer. Everything going well until it asked for a fax number.
Where do I get a fax number
  • 1,113 Answers
just put anything in or leave it blank, you wont be able to use the fax part of your mfc without a land line attached to it
Posted on Jan 19, 2008
My brother mfc 4800 wont copy, it keeps asking for the fax number. Please help
Your fax machine uses the same line as your phone. You will need to read your manual to decide after how many rings you want the fax machine to answer. Generally should be after your answering machine. Your fax number will be your telephone number.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Mar 06, 2014 | Brother MFC 4800 All-In-One Laser Printer
Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Jul 21, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Just bought lexmark 5600-6000 series want pick up on rings to receieve faxes
Are you asking how to set the printer for the number of rings to wait before answering the incoming call? Please go to the Fax menu on the printer and set the number there. Or use the Lexmark Utility that came on the installation CD. Don
Jun 07, 2009 | Brother IntelliFAX 2800 Laser Fax
Cannot receive faxes. Fax is set to auto receive and there is dial tone in machine. Any other ideas?
Call a cell phone from the machine and verify this is the correct fax phone number that shows up
You must be absolutely sure you have an ANALOG phone line. There is no other cure.
Kyocera fax systems are very picky.
Jun 04, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
I cannot receive the faxes. everything else works
It could be a number of things. Could be a phone line issue.
I have seen this with alot of HP style fax machines. It may be to low end to receive from some of the higher end fax machines.
Apr 07, 2009 | HP Office Equipment & Supplies
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cannot fax using my Workcentre M20i
The machine itself can not give that message. You have some tye of phone line issue.
Feb 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Setting fax ringtone
get distinctive ring service from your phone company, that will get you a different number, on the same line, with different ringing pattern, my tel compnay charges $5 per month, then set the fax options to DRPD, and it will go directly to fax machine, while the phone calls on first number, will go to telepehone.....
Feb 13, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
k24674
jasbo
jasbo
