Question about Altec Lansing VS2121 Computer Speakers
HELP PLEASE TO ALL OF YOU, my son accidentally broke the two middle (center pins) that goes in the big orange cable that comes from the right speaker and goes inside the woofer. How can I get a replacement cable, I just need to replace the big fat orange cable that has 3 pins in the first row, 4 in the middle row and 2 in the bottom row. Does any of you have a cable that don't need no more, or help me get a solution. I need to fix them asap, I don't have the mony to buy a replacement. Please help me, I will really appreciate it and thank you in advance for your help and cooperation.
Trinidad Gavidia
  • Eltiburon Jan 20, 2008
    I will give it a try, I will let you know.
    Thank you kindly for your suggestion, I appreciate.
  • Eltiburon Jan 22, 2008
    I just discovered that my son has two different Altec Lansing system, the big woofer is VS4121 and the two little speaker are VS-2121, now what I need the either the correct Woofer to be the same with the little speaker VS-2121 or viseversa, I need speaker that are VS4121 to be the same with our woofer VS4121. The connection are different. That's any of you have either the woofer that is VS-2121 or the little speaker that are VS4121? Pins has nothing to do with the connections. Connection for the VS-2121 and the connection of the VS4121 are different. I took them to an electrician and that is what I was told. So what I have presently that is not working is two little speaker VS-2121 and a big woofer that is VS4121. Please help me? I ask my son how this happened and he said, his cousing who left the county took the wrong woofer with him and left his woofer here.
    New Friend:
Pls. give me the wiring diagram for controller to female plug and male plug because cut the wire all. thank you
Posted on Jul 16, 2013
Try this website
Posted on Oct 06, 2008
    Problem Solver:
  • 11 Answers
Well u could try a shop that sells music equipment they should be very common... but u need to know how to solder :D or at i think they have cables....
Posted on Jan 20, 2008
Hi Jerry
What Model....?
Using a mobile phone camera would have helped in this situation.
Before taking things apart
I'll be very surprised if someone has the same speaker system in bits somewhere
An electronics guy would trace the wire back to it's source to decide what it's being used for.
Good Luck
Review Altec lansing BXR1220 Speakers 8
Altec Lansing Avs300 PC Speakers Sub
Sep 13, 2015 | Altec Lansing Audio Players & Recorders
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through and other vendors. One vendor is .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Broken pin on wire
I am not familiar with this model ... I must ask ... Are these standard electronic plugs? RCA, Mini or micro phone? Mon or Stereo?
Two souces that pop into mind are Altec Lansing or Radio Shack.
Thanks for your interest in
May 14, 2010 | Altec Lansing ADA 885 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Altec Lansing Vs3151 Control Pod
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Jan 12, 2009 | Altec Lansing VS3151 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
919 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
