Question about SVA-USA SVA HD4208TIIIBU 42" Plasma Monitor
Black screen with the cable tv connectit i got black screen all the time. sometimes the black its pulsin, and sometime stays still in 90% of the screen make it unable to wach the picture. can you please help some how.
0 characters
1 Points
Haft of the screen is black.
Most likely, it is some capacitors in the inverter or power circuit that is dying. Check out
Dec 16, 2012 | Sceptre 46" 1080p Lcd Hdtv X460bv-fhd
I have a flat screen Dawoo monitor model L10AV (17"). My mother used to have it on her computer but sometimes the secreen wouldn't go on. The green light would blink but the screen was black. After fooling...
cybertripp, What is correct model number from rear of unit and the date of manufacture? Not cable problem!!! You will need to open monitor and investigate power supply board for "thermal cycle fractured" solder joints on the printed circuit board. You will need large magnifying glass or low power inspection microscope (5x to 20x) to find pesky intermittant solder joints which will need to be resoldered. May also have problem with "BAD" (premature failure) electrolytic filter capacitors!! Swollen tops indicate problem!!! Lots of pictures on web. You need visit to YOUTUBE for DIY video clips of typical repairs to lcd monitor power supply/inverter supply. Then you will know what generates the 600 to 1000v ac required to light the tiny but small diameter fluorescent lamps in back of the lcd panel that is now black and lifeless!!! Do your investigation first to determine if you can handle the repair or contract out the work ($40 to $90) Reply to this response with info on just what you will do about your black screen lcd monitor. 12fixlouie
Oct 15, 2010 | Daewoo L700C 17" Flat Panel LCD Monitor
Dell laptop monitor will not boot sometimes stays black. . .runs in safe sometimes also will lock up in programs...very quick blue screen upon boot sometimes as well can't tell what it is doing.
The issue is not with your monitor. Its with your computer's operating system, it may be corrupted and needs to be reinstalled. Getting on safe mode all the time is also a sign that your hard drive is about to fail, I suggest that you back up all your data now...
Jun 13, 2010 | Computer Monitors
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Acer 5920 screen black out
If movement is affecting performance of a device, most possible chances are you have a loose connection. Please contact the vendor for a replacement of the LCD cable / the LCD itself as the case might be
Jan 11, 2009 | Computer Monitors
Monitor Problem
there may a dry solder inside monitor or signal cable may disconnected internally move it if display changs then cable is faulty replace it
Oct 22, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor blacking out intermittently
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 07, 2007 | ViewSonic VX910 19" LCD Monitor
Black Screen
Busta, Other than making sure all your connections are tight and the swift kick doesn't work anymore your monitor may be telling you its time is almost up. How old is it? Call compaq make a stink if it isn't too old. Not what you wanted to hear. Good Luck, Tim
Feb 13, 2007 | Compaq FP 7020 17" Flat Panel LCD Monitor
SVA-USA SVA HD4208TIIIBU 42" Plasma Monitor Logo
16 people viewed this question
Top SVA-USA Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a SVA-USA Computer Monitor Expert? Answer questions, earn points and help others
