Question about Sony StylePro SDM-S73/B 17" LCD Monitor
Nspector answered a question 4 me and then asked me a question
I had a question yesterday about the monitor I got from E-Bay and the person who answered me (Nspector) asked me the name of the monitor and I didn't know how to respond back to him so I thought this would be O.K. the monitor I have is a Sony SDM-S73/B
  • 293 Answers
SOURCE: Sony SDM-HS73 Monitor huts down after 15 seconds..
Well, open it up and look for the capacitors voltage (example 1000uf 16v). You can get it in any of your local electronic repair shop or radio shack.
Posted on Oct 15, 2008
  • 13 Answers
SOURCE: sony sdm s73 screen black - green light flashing - no amber light
1. If under warranty, take it to the service center immdtly.
2. The display cable might be loose plug it up.
3. Your system might not be giving signal to the display unit. Is the system running, Listen for a beep when u turn on the system. If there is a beep the System Ok for display or the problem might lies in the Tower itself.
Posted on Jan 05, 2009
  • 32281 Answers
SOURCE: Blinking Screen
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty.
You maybe be able to get service, parts and DIY info from LCD Parts. Click on this link to their WEB site :-
These other sites may also be useful.
Posted on Nov 16, 2009
  • 11361 Answers
SOURCE: No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
Posted on Apr 18, 2010
  • 732 Answers
SOURCE: I have problems with colors
tlnwiayqydee, In terms of lcd monitor age, unit is VERY OLD. Cold cathode fluorescent lamps will need to be changed for new ones. Very hard to do for consumer/user!!! Best if you trade-in for new unit. Did you even look at the "date of manufacture" on back of unit? Look here for lamp information: and and and You will need to also visit YOUTUBE for video clips of units being repaired. 12fixlouie
Posted on Oct 15, 2010
  • 11361 Answers
SOURCE: I have a Sony SDM-HS93 (Black) 19 I turn the
It may have bad lamp assemblies, you need the inverter tester lamp to verify. See my pictures here:
This is common problem with the 17" version also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Feb 11, 2011
0 characters
1 Points
Dell E197FPB Power Save Mode
read the monitor manual.. Did you try unplugging it and see if it reset to default when you plugged it back in?
Jun 06, 2015 | Dell Computer Monitors
How do I get my W240D to come out of sleep mode?
Why don't you ask this IT person to achieve correctly its installation ?
Aug 28, 2014 | Hyundai Electronics W240D LCD Monitor
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
Screen goes blank after 3/4 seconds Monitor approx.1 year old
I can confirm the number 3 solution. I have fixed a bunch of these now.
Replace capacitor C202, 680uf 25V. It is usually visibly damaged. It should be a low impedance type, often known as "suitable for switch mode power supply".Even yesterday.
Nov 06, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Rolling Horizontal Lines across the screen
ground loop is problem. Many answers available via Google.
Jul 07, 2009 | Acer AL1916W 19" LCD Monitor
Heard pop sound, then no power
Sounds like your monitor just fried itself.
Since monitors are hazardous, tricky to fix, and are quickly outdated within a year, by a monitor with a bigger size and resolution.
To answer your question: Your monitor is bricked, and will need to be replaced with a new monitor.
Nov 10, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
X2gen MW19R user manual
Maybe they put more volts on it, because of the cable length. About putting the manual on Fixya. I do not know how you would do that. I know that you can have a little more volts and be okay but not enough is bad. Are you sure it is the correct cord?
May 22, 2008 | Computer Monitors
No power
Did you find out what was wrong with your monitor?
Dec 09, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Sony StylePro SDM-S73/B 17" LCD Monitor Logo
Top Sony Computer Monitors Experts
Lala Alonsi
Lala Alonsi
ray gallant
Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
