Question about Intel Motherboard
Need to know how wired power switch and Leds for my board
INTEL - D850GBC ATX MOTHERBOARD SOCKET 423 400MHZ RDRAM (A55888-907)
  • 1 more comment
  • briguy72076 Jan 19, 2008
    do not have manual to this motherboard, got a new computer case trying to hook up power switch and leds , has a usb and sound ports on front too.
    there is power sw ,hdd led,power led +, power led and reset sw, wires
    the pins from left to right read pw, led,c9d,13,pw sw, fnt,pnl
    shows a picture of where the pins are but no description of where go
  • 2,427 Answers
The C at the end of the D850GBC MEANS the brand with a disgnostic connector, the board is the same its shipped differently
Here you are Sir i believe this has everything your require
http://support.intel.com/support/motherboards/desktop/d850gb/sb/cs-013240.htm
and the diret link is for the manual ftp://download.intel.com/support/motherboards/desktop/D850GB/GB_English.pdf
Posted on Jan 19, 2008
  • 4 more comments
  • Rishi Roshan Ali Jan 19, 2008
    Everything is in there from diagnostics led codes, to hooking to the mainboard even wireing it
    Yep those are labeled on the board under the connector, look at page 69 in the manual under C for the connector
    the white wires on the connectors are all negative, the colored ones are positive, you only got to worry about the led;s + and - but if you connected it wrong the led's simply wont light, the power, reset can connect anyhow as long as its connected to power switch. ad reset switch
    the USB has 7 pins like this
    00000
    0000
    the last one is called a key
    the groung connects close to it
    so its basically
    VCC+ VCC- +5V gnd key
    VCC+ VCC- +5V
    thats your usb connection
    If you look at the main board carefully you will see the pins are labeled
    or close to the pins is a diagrgam of how the wins connect, simply follow the diagram of the labels..
    any luck or do u need specifics ?
    Genius:
  • 1,067 Answers
Just like any other use asus tool to show u or look at your other computers mobo match up ps rw like other one all same ok
  • 6 more comments
  • nick helpap
    nick helpap Jan 19, 2008
    if we can geta pic of leads we can see all same tho do u have old computer u can see were the pins go to hdd and ps and rs ? reset in all then just match it up ok
  • nick helpap
    does power lead say 12 ? thats power ok
  • nick helpap
    do that then folloing them verticaliy pw power black on top negative k do rest
  • nick helpap
    go to page 26 on his 1st link ok thats front side conters 2nd row shows u ok see that page 26 for usb ect
  • nick helpap
    i found my conecter asus makes speaker far back to left if your looking at it then ground/ground meens 5+ pled is far right 2 bottem gaped plus to front i could maby take a pic of this for u shows u
  • nick helpap
    thats for bootem row
    top row above pled is ide plusthenide led- then gap over to left pwr and ground next to it then reset ground top far left
  • nick helpap
    get on yahooo msg im nick_helpap ill walk u throw it draw u a pic
  • nick helpap
    hes good just rember across pins make always never down and up test eash way then map it all on paper for later after your done thx agian nick helpap
My pc wont boot up how can i tell what core it is? its a Dell with 2.8 ghz intel
If this holds true,
http://www.ehow.com/facts_7577204_specifications-dell-model-dhm-computer.html
,the Dell computer is a Dimension 8250.
If that holds true, then NO. The motherboard chipset does NOT support using a dual core processor, much less a quad-core.
http://support.dell.com/support/edocs/systems/dim8250/specs.htm
The motherboard chipset used for the technology of your Dell motherboard, utilizes a Northbridge chip, and a Southbridge chip.
Let's regress for a moment;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
If you would take the motherboard out of the computer case, and stand it up in the same direction/position it was in the case, on a table; the motherboard can be viewed as a Map.
The Processor is due North, the Ram Memory slots are due East, the white long PCI slots are due South; and the I/O ports are due West.
The Northbridge chip is always close to the CPU. (Processor)
This is one reason it is named the Northbridge chip.
The Southbridge chip lays down near the white long PCI slots.
Yes. Due South.
The Northbridge chip handles the Faster capabilities of a computer.
Processor, Ram Memory, and HIGH-speed graphics.
Therefore when you want to upgrade the Processor, not only take a look at what processor socket is used on the motherboard; but also see what the Northbridge chip is.
[There is more ]
HIGH-speed graphics being AGP, and PCI Express,
http://en.wikipedia.org/wiki/AGP
http://en.wikipedia.org/wiki/PCI_Express
a) Using a graphics card inserted into a white long PCI expansion slot, is NOT high-speed graphics.
b) Using Integrated Graphics is NOT high-speed graphics.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Southbridge chip handles the Slower capabilities of a computer.
1) Anything connected to the IDE bus. (IDE is also referred to as PATA)
2) Anything connected to the SATA bus.
3) Anything connected to the USB bus.
4) Anything connected to the Ethernet bus.
5) Audio (Sound)
An example of general location using this example,
http://en.wikipedia.org/wiki/File:ASRock_K7VT4A_Pro_Mainboard_Labeled_English.svg
The motherboard example is clocked 90 degrees to the Left, plus a few more degrees (22?); than how it actually is positioned in a computer case.
As you can see with this example, the Northbridge chip has an aluminum finned Heatsink on it. They run hot, and need to be cooled.
The Southbridge chip in this example does not use a Heatsink.
Most newer motherboards do.
The motherboard chipset used on the Dimension 8250 motherboard, is an Intel 850E.
One of the first Intel chipsets to start supporting Intel Pentium 4 processors.
Age, my man. This baby is O-L-D.
Dual core processors weren't even heard of then. They hadn't come out.
Much less quad-core processors.
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Fourth listing down in the Chipset column. 850E
Northbridge is Intel 82850E
Southbridge is Intel ICH2. Part number is Intel 82801BA
-> RDRAM?
Just spotted this.
Should mean you are running an Intel Celeron, or Intel Pentium 4, that use a Socket 423.
Seriously? RDRAM?
That ram memory technology has been left way behind.
Rambus DRAM. (Dynamic Random Access Memory)
http://en.wikipedia.org/wiki/RDRAM
Plus the price of Ram Memory is out-freaking-rageous!
For the price of 1GB of RDRAM, you could buy 4GB of Sdram
DDR, DDR2, or DDR3.
Advise get rid of that motherboard.
Processor? Nope. Can't reuse. Why? It's a Socket 423 Intel processor. They use RDRAM ram memory.
Intel made a deal back in the day, that they would manufacturer Intel processors utilizing a Socket 423, and RAMBUS ram memory,
http://en.wikipedia.org/wiki/Socket_423
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Willamette_.28180.C2.A0nm.29
Regards,
joecoolvette
Feb 04, 2013 | Dell Computers & Internet
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
I need a motherboard that can use the same case and everything els as the p4vmm2 My case is the ATX with Intel celeron 2,4GHz
you can use any ATX mainboard into an ATX case, they are universal. Your cpu will only fit boards with the same cpu footprint so you need to know what socket your cpu is.. lga775 is most common now. I would advise a Gigabyte EP45-UD3LR board. Excellent board and well worth the outlay.. no issues with windows xp or vista and you can expand drives and ram as you wish..
Nov 02, 2009 | EliteGroup P4VMM2 Motherboard
Looking for the manual for a Gateway 700S PC. Specifically 2 questions ... 1) how do I open the ATX tower case? and 2) what EXACT memory specs do i need to upgrade this unit from the 256MB that it came...
for the memory upgrade, your system used RDRAM RIMMS.
it supports the following memory modules (which must be installed in pairs).
and as for opening the case, you there should just be ~2 screws on the side panel away from the motherboard ports that you can remove and it will slide off, or there might be 1 or 2 thumb screws.
64MB Module 64MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-136 128MB Module 128MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-079 512 MB Kit 256MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-081 64MB ECC Module 64MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-134 128MB ECC Module 128MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-080 512 MB ECC Kit 256MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-082
Jun 24, 2009 | Gateway 700 X PC Desktop
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
Intel Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
