Question about Canon Rebel XT / EOS 350D Digital Camera
Screen black Hi, I just got a new Rebel, out of the box. I put the battery and CF card in, turned it on and the screen does not show anything. The menu options do show up and I can take a picture it does record it and I can view it on the screen. But, when I want to shoot a photo the screen is black.
  • 667 Answers
The camera is fine. Since it is an Single Lens Reflex (SLR), it is not possible to use the LCD screen to compose your pictures. Canon answers that here: CanonUSA
Click on the frequently asked questions
Posted on Jan 28, 2008
No Power To Canon Digital Rebel XT
I believe this post will help you out..
May 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel won't turn on, red light next to "CF"
Assuming you have tried another card you know to be good...
Remove the memory card, main and backup battery, switch the camera on for 10 mins. While you are waiting look into the memory card slot with a torch and make sure none of the pins at the bottom are bent.
If there is this will mean opening the camera to straighten it or sending it in for repair.
If not refit backup battery and main battery and cross fingers..:)
best of luck
May 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I'm having 3 different problems with my Canon Rebel XT
According to Canon, Error code 02 means that "There is a problem with the CF card. Try any of the following: Remove and re-insert the CF card. Format the CF card, use a different CF card."
Are both CF cards the same brand? Sometimes some brands have conflicts with the camera, you might try using two different brands.
It may not be the card, did you try on the third attempt to remove the battery and put it back in? There may be a problem with the contact points where the CF card plugs into the camera, or in the transfer system itself.
Dec 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Extreme Difficulties With My Canon
Problem #1
this is not a problem.. if you leave the camera in the ON setting for long enough.. it goes to sleep ... in order to conserve battery life.. you need to keep some of the buttons pressed for a bit for it to wake up... e.g. keep the picture taking button depressed for 5 secs.
Problem #2
If you were checking the pictures after just shooting them then its probably a CF card problem. You can also get the same error .. i.e. corrupted files from the cameras perspective.. if you use a CF card reader and try to change the pictures on the card.
You should try to connect the CF card that has those pictures to a computer it might be able to open them.. .
Otherwise try another CF card.
Nov 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Sounds like a corrupt format on the Compact Flash card.
Take the bettery out, then the CF card. Put the battery back in but don't put the CF card in. Switch the camera on and see if you get a different error on the screen. If you get something like 'Missing card' then the camera is OK.
You will probably have to plug the CF card into a PC/Mac via a card reader to see if you can reformat it. If it doesn't work I'm afraid it will need replacing.
Nov 05, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
113 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
