Toshiba satellite start up
I recently rebooted my computer after removing lotus notes from the hard drive and the computer wont go past the toshiba start up screen where it says press f2 for setup menu or f12 for network boot menu. i try to press either of the buttons and nothing happens.
    Problem Solver:
  • 5 Answers
Maybe you lost your COMS you should recharg it
Posted on Jan 19, 2008
6ya staff
SOURCE:
Error lotus note
The problem you are experiencing could come from a number of sources. You could be having a version conflict with the OS or a recent update. You could be having a corruption of you Lotus software. You could be having interference from some other background software. Or you could be experiencing an impending failure of your hard drive or other system component. Here are some steps you can take:
1) Re-install Lotus. I generally like to uninstall the software first, then reinstall it, but sometimes just reinstalling does the trick.
2) Do a system restore (if possible) to before when the problem popped up. This insures that it is not a conflict with a recent update.
3) Do an EXTERNAL hard drive scan for viruses. EXTERNAL means pulling the hard drive out, attaching it to another system and using that system to scan for viruses. It is the only way to be 100% certain to catch ALL viruses. Then put the drive back and scan internally for spyware/malware.
4) Turn off all unneeded background programs. Run "msconfig" from a command prompt and turn everything off under the "startup" tab and all the non-Microsoft services under the "services" tab. Restart the system and test. NOTE: this will disable your antivirus and anti-spyware protection so generally stay off the Internet until you turn them back on at the end of the test.
5) Finally, if the problem is still there, do a hard drive scan. But first make sure you have backed up your data! (Just in case the system finds a lot wrong). To scan your drive: Go to "My Computer", right button click on the boot drive (usually the C drive). Select properties, Tools, Check now button. It will tell you that you have to do that when you reboot because you can't do it now. Let it do it when it reboots.
Well, that's the standard set of things we do here to troubleshoot bad software. Personally, I suspect the HD myself since the problem is intermittent. But the other steps may solve the problem without having to drag it into some repair shop.
Dec 06, 2013 | Microsoft Windows Server Standard 2003 for...
My toshiba satellite l645d is giving me error message check connection cable no bootable device
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 01, 2012 | Toshiba Satellite L645D-S4036 Notebook
Hi everyone!! I've readed all the posts you've made, but my trouble is a little bit different. I'm trying to install XP on a toshiba satellite T215D-SP1002L, but when finishes to load all the drivers and...
I understand your problem.
As you have indicated, the problem occurs just after installation of XP and the Toshiba hardware drivers.
From past history, the most likely device would be the wireless driver, and then maybe the audio or graphics driver.
Reboot your computer and press the F8 key, when the boot selection screen appears, select Safe Mode. Many device drivers will not be loaded in this mode. If the blue screen does not come up, then go to device manager and disable the wrieless device and reboot normally. If no problems, you should go to the link I have provided below by copying and pasteing into your web browser to the support page for your Toshiba model laptop. Select your wirless device driver for your XP operating system, download and and install, then reboot. Your may have to do this for other hardware as normally this is a primary cause of the system shutdowns.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2707772&rpn=PST2LU&modelFilter=T215D-SP1002L&selCategory=2756709&selFamily=1073768663
Jan 11, 2011 | Microsoft Windows XP Professional With...
COMPUTER WONT BOOT UP ....GIVES MESSAGE OF UNMOUNTABLE BOOT VOLUME/ WINDOWS WONT START
Your hard drive might be bad - go to the setup or BIOS and check if it's detected. If it's not listed then check your hard drive - re-seat and reboot the computer.
Dec 15, 2010 | Toshiba Satellite P205-S7476 Notebook
My Toshiba Satellite 4010CDS Laptop never gets past boot. When I turn it on it goes to the Toshiba splash screen and never goes past that. The hard drive makes a lot of noise when I turn it on also. Thank...
What OS are you running?
Did you recently install a new app?
Did you recently install a new hard drive?
Try and do a system restore boot the computer in safe mode with networking to do this you:
  1. Turn on laptop
  2. While booting up press and hold F8
  3. Until you are brought to a boot up option page with different ways of booting up
  4. Click safe mode with networking
  5. When you do this computer will load and click system restore
  6. Restore computer to a previous date when it was working
Sep 18, 2010 | Toshiba Satellite 4010CDS Notebook
TOSHIBA Satellite Pro 4300 series 12 gb hdd Problem: I get Blue Box Error after windows Xp load screen. I try to enter in safe mode and still blue box error. Doesnt matter what i do the blue box...
XP is dead. Don't waste money on it. Download a free, safe, modern operating system and install that. I have an old Toshiba and it runs Puppy Linux, but you might like Mint or Zorin, or Lubuntu if it's a 32 bit system. download one or two onto flash drives or CD, and give it a spin. Puppy will run off a CD, even if your hard drive is bad.
Why Linux is Better
http://nfp.freehostia.com/jims-intro-to-linux.html
Apr 09, 2017 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Scratching sounds coming from laptop
There is lint or small scrap of paper rubbing on the cooler fan.
Without disassembly, Blow compressed air into the exhaust port while power is off, this might dislodge the debris.
Otherwise you have to remove outer cover and clean out that way.
Jul 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Replaced hard drive now computer wont boot
If you have a restore CD/DVD that came with your Toshiba, you may have to use it to reformat your hard drive and do a fresh installation. You may have a bad sector or cluster and the boot file is located on it. Try this and check the bios for the setting of your hard disk too. Try starting the system on safe mode by pressing F8 at boot time.
Mar 21, 2009 | Toshiba Satellite® A135-S4467 PC Notebook
Toshiba L300D-18E... won't load up past splash screen
Less than four months old (still in warranty), just back from hard drive replacement (recent service issue). Take/send it back as this is a warranty issue.
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba Satelite A105-S4211 wont log in
I recently ran into a computer doing this.
Try what jmagnu said, hopefully it will work for you (safe mode didn't help me).
I basically had to remove the hard drive from the computer, install it into another computer and run a ton of virus, malware, spyware scans on the drive.
I used a combination of AVG, superantispyware, malwarebyte's malware remover, hijackthis, ccleaner, and a few others who's names escape me.
Best of luck :)
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
Computers & Internet Logo
248 people viewed this question
Ekse
Marvin
Marvin
