Question about Tascam 122MKIII Single Dual Cassette Deck
Need a tec to repair
Tascam 122MkIII
TASCAM DA 30 DAT
HHB CD RECORDER
ROLAND GROVE 303
  • jimmyv448 Feb 17, 2008
    Picked up a used Tascam 112 MK II deck for $10 but it is not delivering audio out. Have some leads on local shops but wondering if anyone has a clue about likely cause or range of cost to fix?
  • Graeme Ross
    Graeme Ross May 11, 2010
    where abouts in the world are you? I am in Australia and can help you. :)
  • 1,512 Answers
I can help you if you are in Queensland Australia. :)
Posted on Feb 01, 2008
6ya staff
SOURCE:
How do I fix a Tascam DA-38 Multitrack Recorder?
It needs cleaning and new belts some of which are very hard to find because they are smaller than a dime. It can be fixed if the Pinch Roller is not cracked.
May 30, 2015 | Miscellaneous
Where can I get tapes for a tascam da -30 mk2 and what are the tapes sizes?
You need what are called "DAT TAPES". Just like Blank analogue audio cassettes they come in a range of lengths fro 15min to 180min. You'd be better off to use something like a 60 or 90min IMHO. Dat tapes can be purchased from places like "studio spares" or any other PRO media supplier. They can be quite pricey. I tend to buy mine in bulk on ebay.
Before you ask, not there are not different tapes for different machines, but the btands do vary. I use either HHB or AMPEX. DO NOT USE COMEPUTER DATA BACK UP CARTRIDGES as a cheap alternataive.....they are different and end up giving you a lot of loss and errors over the years...sometimes instantly (Tale it from experience!)
Best Of Luck
Sep 07, 2010 | Tascam DA-30MKII
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
May 31, 2010 | Tascam HHB DA30 Tape for DA-88
I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Dec 03, 2009 | Tascam Audio Players & Recorders
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What...
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Nov 17, 2009 | HHB BurnIt CDR830 CD Recorder
HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Dec 26, 2008 | HHB CDR850 CD Recorder
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
How do i transfer from tascam DA-30MK11 to computer
From my personal experience, and assuming that you want to do this purely in digital format in order to preserve quality, you need to connect an RCA cable from the digital (SP/DIF) output of the DAT machine to an SP/DIF input of a sound card installed into your computer. Please note that the sound card on your computer must have digital input capability. Also the Digital input (sometimes labeled ‘CD digital’) must be selected in your software as part of the recording controls. To do this, open Volume Control, click ‘Options’, select ‘Properties’ and then select ‘Recording’ (as ‘Playback’ is usually enabled as default), and select the ‘digital’ input. Then using a reasonably good a sound editor or other recording software, start recording keeping in mind that you should configure the software to accept whatever audio data format is used on the DAT tape (i.e. 16 bits, 44.1KHz, or 48 KHz etc) I’m my case the software usually displays a box with these parameters before starting to record. Hope This helps. Good luck!
Nov 03, 2008 | Tascam DA-30MKII
Tascam 122MKIII Single Dual Cassette Deck Logo
191 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
