Question about LG KU990 Viewty
3gnetopt.exe to allow htc TyTN II to act as modem for laptop
Have seen this in the manual for the Pocket PC and was directed to downloadd off the CDs provided. No joy there.
Is there a place on the net where I can download this file?
Cheers
Lachlan
  • Anonymous Feb 03, 2008
    Yeah I have the same instruction but nothing on the supplied CD
  • that_i_know Mar 18, 2008
    I don't have 3gnetopt.exe.
IT WILL ONLY CHANGE THE SERIAL COMMS SETTINGS OPTIMIZED FOR HIGH SPEED DATA (ANY TUNING SOFTWARE CAN DO THAT) AND CREATES A DUMMPY SERIAL PORT REDIRECTOR LOOK AT www.xda-developers.com/
Posted on Feb 24, 2008
Can not import contacts from tytnII to pc
Simply download and install the software necessary to do so. In this case the "HTC Sync" application located here http://www.htc.com/managed-assets/support/software/htc-sync/setup_3.0.5579.exe
Installation Instructions located here: http://www.htc.com/au/help/install-htc-sync/
Sep 26, 2011 | HTC TyTN II Smartphone
My htc tytn ii stays on align screen after hard reset
It seems it might be a problem with the installed ROM (corruption of some sort).Installing an original ROM (which can be downloaded from HTC's site) should fix it.
http://www.htc.com/www/supportdownloadlist.aspx?p_id=13&act=sd&cat=2
Mar 09, 2011 | HTC TyTN II Smartphone
Looking for HTC TyTN II software to connect to PC.
Hello
If you need software on your HTC TyTN II software to connect to PC go to the sitr below and download varieties of software.
www.htc.com/europe/supportdownloadlist.aspx?
Thanks.
Sep 06, 2010 | HTC TyTN II Smartphone
Gprs settings in kerala bsnl for htc tytn II P4550-pls help me?
Manually you can try to give the apn as 'gprssouth.cellone.in' and username/ password as blank.
Jul 26, 2009 | HTC TyTN Smartphone
How to format SD memory card in HTC TYTN II smartphone
To format your SD card, simply unplug it from your PDA, then plug the SD Card into your PC/Laptop (using builtin card reader or one of the USB Card Readers), then open "My Computer", right click the SD Card's icon and format it. Hope this helps.
Jun 01, 2009 | HTC TyTN II Smartphone
I would like to change my language to french help htc kaiser
Reflash to the french HTC Kaiser/TYTN II ROM.
http://rapidshare.com/files/117059726/RUU_Kaiser_HTC_FRA_3.28.406.0_radio_sign_25.83.40.02_1.65.16.25_Ship.exe
Make sure you are connected via ActiveSync in Windows XP before running the RUU (Flash program) then follow the instructions.
Jul 04, 2008 | HTC TyTN II Smartphone
TyTN II - Keep the phone screen alice during a call
Received the following reponse very promptly from HTC Support
---Quote---
This is actually a function of the phone and not a fault. It was designed so that when you were on a call and had the phone against your ear that you didn't accidently tap on the screen and open functions or end the call etc. If you wish to access the touchscreen while on the phone you can press the power button on the side of the phone to turn the screen back on. I have attached a 3rd Party Application that allows the screen to stay on while you are on a call. Follow the below steps to install the program. Attached is a patch for the TyTN II screen blackout issue.
This is not an official fix.
  1. Copy the KaiserTweak.zip folder to your pc's desktop.
  2. Connect you device to the pc via ActiveSync.
  3. Use the Explore function in Active Sync to copy the KaiserTweak.zip folder to the windows directory on your TYTN II.
  4. Disconnect your TYTN II from the pc.
  5. Open up file explorer on your TYTN II and go to the windows directory
  6. Unzip the folder to the windows directory on the TYTN II
  7. Run the Kaiser Tweak.exe to install the patch.
  8. Adopt the recommended configs, not the default.
  9. Soft reset the TYTN II by pressing the stylus into the little circle hole on the bottom of the handset.
If it doesn't work first time hard reset and try again. ---End Quote --- Thanks to the FixYa guys for thier intererst in this topic and problem Cheers Corpcc
May 12, 2008 | HTC TyTN Smartphone
LG KU990 Viewty Logo
1,847 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
