Question about Pioneer DVR-112D DVD RW Dual Layer Burner
Burning a dvd
I can burn CD's but I keep wasting my DVD blanks. Everytim it looks like it is doing something, but after the burn process the disk is blank. Can someone help me before I break something?
  • Sumotoad Apr 03, 2008
    Using nero or roxio and media player all stop writing cd's after a few tracks if im lucky. Generally though writes 4% of track details then says burn process failed. Have 2 of the same drive both have a similar problem.
  • 29 Answers
What software are u using? If you have nero then it should be easy. Study on the kind of software u are using. Look at the recorder option, all options should be unchecked, especially high compatibility mode.
Posted on Jan 19, 2008
6ya staff
SOURCE:
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
I cannot burn files into my DVD-RW drive anymore. I updated my audio & display drivers after experiencing problems with my audio & display. Now, the Nero program starts the burning process but the...
You may have to delete the device in the "device manager" and reinstall it with the laptop restore disk or download the latest drivers from the Toshiba site for laptops.
Also this DVD-RW may not like +R disks or +/_ Disk . It may only like -R disk.
Jun 22, 2010 | Toshiba Satellite A100 DVD/CD-RW Combo...
Its says write error when I go to burn a avi file onto a dvd disc
Is the AVI file less than 4.7 GB in size?
Does the "write error" happen more than once?
Did it happen only with one "blank" disk?
Can you select some other file, and successfully write it to a disk?
How many seconds after clicking "start burn process" does it take before you get the error-message?
After getting the "write-error", look at the disk.
Does it appear that anything has been burned onto the disk?
If you put the disk into some other DVD-reader, is it still reported as 'blank" ?
Jun 12, 2010 | Computers & Internet
It wont record on 16xdvd+r discs? what is the properdisc
  • Media Type that the unit will play CD , DVD , CD-R , SVCD , CD-RW , DVD+R , DVD-R , DVD+RW , DVD-RW , DVD-ROM , Video CD
  • Media Format PAL , NTSC
  • Recordable Media DVD+R , DVD+RW only.. It will not record on the more expensive and compatible DVD-R, DVD-RW.
  • I recommend burning at a slower speed such as 2.4X, 4X or at most 8X.
  • I had similar issues resulting in many "coasters" for drinks burning at a faster rate even with my computer. Although some disks are designed to burn at a faster rate, software and components sometimes cannot keep up resulting in wasted money and time.
  • It may also be the media (manufacturer of disks). No matter which DVR or Burner you may have certain hardware schemes do not like certain media. It is a trial and error process. Just make sure the store has a return policy for the disks if they don't work. I have never had a problem returning disks to Staples that did not work.
I hope this helps and good luck.
Oct 27, 2009 | Gateway AR-230 DVD Recorder
CD/DVD will not burn DVD
Did you tell CDBurnerXP that you want to burn a CD? or to burn a DVD?
Does this happen with _EVERY_ "blank" disk that you insert, or just one disk?
Can your DVD-RW _read_ a previously-recorded CD? DVD?
If not, then that hardware is suspect.
Sep 14, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Redone windows xp.... now cant burn dvds
There are dozens of free perfect functioning  burning software. the one that i use is Totally Free Burner 3: as the name says it's free, extremely small ( just 1 MB compared to 100MB for Nero), fast and very easy to use. get it from here http://www.softpedia.com/get/CD-DVD-Tools/Audio-CD-DVD-Burning/Totally-Free-Burner.shtml
Jan 21, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Cannot backup files to a cd/dvd
we may need more details but you can try this for now
1. are you sure you have a cd writer or a dvd writer (writer = burner)--- check the front edge of your cd/dvd unit and look for words like "writer" "burner" or writeable next to the word dvd or compact disc... keep in mind not all cd/dvd writer can write (burn) cd or dvds, some may burn cd but not dvds.
2. is your cd/dvd unit compatible with the media (cd or dvd blank disk) you are trying to use.. depending your cd/dvd especifications your dvd/cd drive is compatible with certain types of cd or dvds that are writeable.
3. is the cd/dvd a writeable cd/dvd and is compatible with your cd/dvd drive? for instance.. if you are using a blank dvd and your cd/dvd drive only burn cd/s and read dvd and cd you won't be able to write to the blank dvd.
4. are you trying to burn a dvd in a corporate computer.?? as a user (not an administrator) of your corporate computer you may not have priviledges that will allow them to burn dvd/cd's even you your drive and your media are compatible.
please post
the error that you get
the brand and model of the computer you're using
the type of media you're using
Oct 02, 2008 | Computers & Internet
Pioneer DVR-112D DVD RW Dual Layer Burner Logo
47 people viewed this question
Top Pioneer Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
