Question about Samsung HP-R5052 50 in. Plasma HDTV
NO VIDEO TOTALLY BLACK SCREEN ON R5052 PLASMA. HAVE AUDIO AND CAN CHANGE CHANNELS WITH DIRECTV HD RECEIVER BUT VIDEO NEVER APPEARS. STARTED OUT COUPLE OF MONTHS AGO AS HORIZONTAL BLACK STRIP COVERING 50% BOTTOM OF SCREEN. LASTED FOR FEW SECONDS TO FEW MINUTES AND WENT AWAY. HAPPENED 2/3 TIMES DAILY. HAVE BEEN ADVISED THAT ITS PROBABLY THE "PLASMA PANEL" WHICH INCLUDES THE POWER SUPPLY AND "CIRCUITRY BOARD". UNIT MANUFACTURED 2005. HAD ONE YEAR EXTENDED WARRANTY AND LET IT EXPIRE IN OCTOBER 2007. ANY SUGGESTIONS. THANK YOU VERY MUCH.
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Posted on Apr 12, 2008
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Onkyo 605 loss of audio on HD channels only
on your directv box, go to menu, setup, setup again, then audio, then dolby digital on the right and turn it on. assuming you have an optical audio cable from your sat box to your onkyo.
Apr 26, 2009 | Onkyo TX-SR605 Receiver
No sound for HD channels Denon 2307
Need more detail - What is your TV source (directv, cable, etc,) Also - how is it connected to the Denon?
Apr 01, 2009 | Denon AVR-2307Ci Receiver
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Ittermittent digital audio drop out on some channels
Did the issue ever get resolved. I have similar issues with a connection to Cox Cable HDTV and Onkyo TX-DX989. All sources (DVD Player) sound fine and not issues except channels 706 and 710 on Cox Digital receiver. I had Cox replace the HDTV receiver and the same issue occurs. I've tried optical audio and also the COAX audio ports with the same issue. The workaround I have found is to set the audio to "Other" on the Cox box, but the volume then has to be turned up quite a bit.
Jan 16, 2009 | Onkyo TX-DS989 Receiver
Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Jun 24, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Hi
Have questions about your upgrade? We've got the answers. What do I need to do to receive my upgrade? Nothing! Just make sure your DIRECTV HD DVR is continuously connected to your land-based phone line and you will receive the upgrade automatically. When will I receive my upgrade? The 6.3 software upgrade will roll out over a period of several weeks. Customers with more than one DIRECTV HD DVR may receive their upgrades at different times for each receiver. We appreciate your patience while we deliver these new and improved features to eligible DIRECTV HD DVR customers nationwide. Are all DIRECTV DVRs receiving this upgrade? No. DIRECTV DVR models SONY SAT-T60, PHILIPS DSR6000R and HUGHES GXCEBOT will not receive the 6.3 software upgrade. Other models received a similar upgrade, 6.2, in the past. I have a DIRECTV R10 DVR with 6.1 software. Will I receive this upgrade? No. The 6.1 software on the DIRECTV R10 DVR already includes the 6.2 features such as folders and faster menu scrolling. Will any of my DVR settings be changed as a result of the upgrade? Yes, some of your settings or preferences will be changed back to the factory default settings as a result of the upgrade. These include: "Favorite Channels," "Channels You Receive," "Spending Limits," "Clear Channel Banner Quickly" and "Dolby Digital" recording and output. To change Channel Banners, Channels You Receive and Favorite Channels preferences: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Channels" To change Spending Limits: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Parental Control" To change Dolby Digital Settings: 1. Select "Messages and Setup" 2. Select "Settings" 3. Select "Audio" 4. Select "Dolby Digital" and "Digital Output" Will I be charged for this upgrade? No. We're upgrading your DIRECTV HD DVR as part of your normal DIRECTV® DVR with TiVo® service at no additional cost. What happens if I don't have my phone line plugged into my DIRECTV DVR? You will not be able to receive the upgrade if your DIRECTV DVR is not connected to your phone line. To install the upgrade, your receiver must successfully make a call to our servers. How will I know when I have received my upgrade? You'll receive an on-screen message the first time you visit DIRECTV Central after your upgrade is complete. It will also appear in your Messages section. You can also check your System Information screen to find out which software version you currently have. Will the download delete any of my currently saved programs? No. All of your saved programs will still be there for your enjoyment after the installation. Once your upgrade is complete... How do I activate the Grouping (folders) option? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change groups to ON. SHORTCUT HINT: While viewing your Now Playing List, press number 2 on your remote control and your Now Playing List will change from the GROUPS view to show each individual recording. Press 2 again and it will switch back to the GROUPS option. How do I sort alphabetically instead of by date recorded? 1. Go to your Now Playing List. 2. Press Enter on your remote control. 3. Change sorting option to Alphabetical. SHORTCUT HINT: While viewing your Now Playing List, press number 1 on your remote control and your Now Playing List will change from alphabetical to date sort. Press 1 again and it will switch back to alphabetical sort. Some settings will restore to factory defaults when the new software is download
Aug 19, 2007 | RCA DRD485RG DirecTV DTV Receiver
Audio vs Video
Happens mostly on your local channels right? This is a issue with the local broadcaster and not directv. Due to the digital transition this has been a widespread issue. Until the local affiliate for NBC, ABC, etc. fully transmit a digital signal then this sync problem is to be expected.
Mar 17, 2007 | Insignia IS-LCDTV32 32 in. Television
Samsung HP-R5052 50 in. Plasma HDTV Logo
772 people viewed this question
Jerry Greenberg
Jerry Greenberg
