Question about Equator 23 in. WB72 / BB72 Built-in Dishwasher
Replacement hose connection for Equator 3500
Hi, our hose sprung a leak at the faucet connection joint. Can we buy a replacement hose?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 37 Answers
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website and also place the order online.
Posted on Feb 26, 2010
Replacing hose on a Kohler model numbe K- 10433
Mar 11, 2014 | Kohler Model 10433: Fort® Single-control...
Leaky faucet
Need more info. Is it leaking in between the faucet and hose or the end of the faucet or around the handle of the faucet? If leaking between hose and faucet a little rubber washer will do the trick. If its the faucet it could be inside the faucet. You can buy a new one, or take it apart and take your parts to the local hardware store whom can assist you there. If its around the handle simply tighten screw ontop of handle.
Nov 11, 2012 | Washing Machines
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
Can thee hose be fixed if it has a leak.
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Feb 07, 2010 | Karcher Hose Reel
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
Leaking faucet ff1280r846,1200r692underneath,when lever is open water is running below off spray nozzle..
hello. pull out the spray nozzle and turn on the water. The water is either leaking from the hose, or from the connection. If the hose has a hole in it you will have to replace it. If the connection is leaking, disconnect it [with the faucet off], put some teflon paste or teflon tape on the threads and reconnect it.
Aug 16, 2009 | Plumbing
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: Fort® Single-control...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Equator 23 in. WB72 / BB72 Built-in Dishwasher Logo
70 people viewed this question
Top Equator Dishwashers Experts
Paul Carew
Jaye t rock
Are you an Equator Dishwasher Expert? Answer questions, earn points and help others
