Question about SanDisk Sansa e250 MP3 Player
Bright White Screen
When I plug my ear phones in the screen goes bright white. also when i have my ear phones unplugged and i push down on the top of the scroll wheel the screen goes bright white but i can still use it and listen to music.
  • 1 more comment
  • lattestone Jan 21, 2008
    I'm not really understanding what your saying. i turn off the player by pressing or holding the power button for 15 seconds? also turn the hold button on and off? then turn it on and its fixed?
  • jtmwa Mar 10, 2008
    the screen stays white
  • Gene Isaac Aug 02, 2008
    I have changed out the old battery and replaced with a brand new battery and this did not fix the problem.
Just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Posted on Jan 20, 2008
Screen goes white when plugged in
How white? Stark blinding white? Or just too bright? The latter is normal. Just manually adjust the brightness when you plug it in using the 'fn' key and the icon that looks like 'decrease brightness' (usually a smaller sun or a sun with a down arrow).
Oct 25, 2013 | Toshiba Satellite L305-S5875 Notebook
Princeton 19" went from bright white to dull white
david78910, First disconnect and reconnect the monitors VGA plug from pc vga port a few times to make sure of good connection at the port. Report back here with results! If that doesn't fix your "pink screen" symptom, then possible bad inverter supply inside unit or the CCFL tubes may have lots and lots of "on" hours use on them and need to be replaced. Yes, you could also have bad (almost dead) switch-mode-power-supply inside unit if "known-good" monitor works perfectly with your pc. 12fixlouie
May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
I have a problem with my M140 Dell XPS LCD display. I have a white patch from top to bottom not complete screen but a portion of it. Do I have to replace LCD or inverter
This is most likely cased by your LCD screen being defective.
The inverter will either light the back light or not, it does not have the ability not to filter certain parts of the screen. It could however be that if your seeing wash out and it goes from super bright white to a dimmer bright white the inverter has failed and the bulb is running at full power.
Most likely it is your LCD.
To test your inverter, turn your computer off.
Press and HOLD the FN key while pressing the POWER key.
Once you see booting dell diagnostics, or something similar you can release the FN key. You might have to release the POWER key sooner if the under shuts down.
Oct 24, 2009 | Dell Inspiron XPS M140 Notebook
My 60PP93 5217 The white is very bright and the
You can carefully remove the rear top cover ( make sure it's unplugged) and carefully wipe the dust off the projection lenses and mirror and inside screen and stay away from the electronics and capacitors.Years of dust build up can blur the picture and give it a glarey picture.
Oct 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
The monitor comes on and then goes to white screen.I unplug it then the same thing whites. I unplug it and it comes on perfect then it whites out again
Hello there... Try minimizing its light. It may be too bright, that's why. It worked for me so I hope this helps... :D
Best wishes, Ai-ai
Oct 06, 2009 | HP Pavilion F1703 17" LCD Monitor
Goes right to a white screen and stays like that
transfer all your contacts and pics to ur computer and go to phone , then security , then press reset , enter your code which is the last for digits of ur number unless u changed it and it should work , when you unplug battery for about 2 days , to be safe
Sep 27, 2009 | Motorola Mobility Rival A455 Cell Phone
My LG Viewty screen goes bright white when i turn it on?
Have you solved this problem because i have the same problem with my viewty and would be grateful to know how you have solved it.
Jul 06, 2009 | LG KU990 Viewty
I replaced the 3 capacitors now there's just bright white screen
Open your monitor back up and look for unplugged connectors, especially the one to the back of the LCD. I had this same problem with a HP F1703. The owner whacked it so hard when the backlight stopped that they dislodged the connector.
Feb 27, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
SanDisk Sansa e250 MP3 Player Logo
120 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
