Question about Logitech Webcam
Video reception comes on and off
The other party is able to see me clearly via video however I have difficulties seeing a continuous picture of that party. Reception seems to turn green once the start video button is activated. Why would this be so?
    Genius:
  • 1,067 Answers
Video card drivers run a ccleaner a clean up tool get u fast agian get latest flash adobe in and java dl latest yahoo msg or aim
Posted on Jan 19, 2008
TV not working
Are you using the correct input for tv reception?
If you are getting the LG screensaver then that suggests that the video circuits are good. Since the menu is working, try connecting something to one of your video inputs and see if that works. It should.
If so, then the difficulty lies with the fact that there may be something wrong with the tuner section of your television.
Aug 29, 2015 | Televison & Video
I get lots of litle squres when on my lg tv then it clears
SQUARES = Digital TV Picture made up of Square Block . if reception poor , or breaks up . you somtimes see the SQUARE BLOCKs on your Screen
Mar 15, 2015 | LG Televison & Video
Creating DVD with pictures and music
Check out a program called convert X to DVD. I believe it provides the function that you require.
May 08, 2013 | Roxio Creator 2012 Special Edition -...
Fuzzy channels all of a sudden, cannot figure out how to get reception again?
Sounds like your cable has become disconnected at some point between the television and the outside connection. Start by unplugging the cable at the rear of the TV and then reconnect. Check the picture. If no success, then trace the wire back to the next connection point and disconnect and reconnect. Continue to trace your line until you get to the point where the outside cable connects to the house. If you do not get a clear picture, then you will need to purchase a new cable.
Jan 23, 2012 | Televison & Video
Sound but no picture just horizontal pink lines
Hello!
I don't think, that "antenna" has something to do with that. Unless you forgot to change reception mode to Digital TV(broadcast). your display should show channel ## looks like: 3-1, or 3.1 an so on. also, the menu on TV must be shown clear in any case. If that's not a case, all you see is just those lines, blame the TV itself. T-con module or display panel is at fault. Try to run DVD player via TV. If you still see those lines, TV needs repair.
Thanks,
Alex.
Dec 29, 2011 | Toshiba Televison & Video
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
Pal reception on tv screen. how can i play my ps2 in normal reception.. what should i do?
To use a european console in other regions that have SECAM or NTSC, you need your playstation to be modded.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
One channel on LCD not clear picture help!
this is a problem with the reception in your area. It should be resolved with an adjustment of your antenna to a location of clear reception.Ask someone in the house watch the television while the antenna is being adjusted for best reception and set the antenna. If you have cable, you must contact the cable company and ask them if they have a resolution to the reception problem. Hope this helps you with your problem.
Apr 25, 2009 | Insignia LCDTV26 26 in. Television
Picture sixe reduced and picture breaks up with converter box
You can change the way the channels can be displayed/viewed by a video setting, consult manual. When pic breaks into pixels and sound goes it's usually a reception problem so you'll have to adjust the antenna facing a direction that makes that channel come in clearly. It helps to experiment with positions and antennas.
Nov 17, 2008 | Insignia Digital-to-Analog Converter for...
Poor cable connection
radio shack sells type f/rca adaptors
Jun 28, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
