Question about Acer Aspire 3680 Laptop
Dc connection overheating
We had a bad connection with the dc board, had acer replace the dc board once. Problem started again, this time it caused it to get really hot, with a horrible burning smell. We unplugged the laptop and shut the lid till the next morning. When i went to open the laptop and after I turned it on, there was a 2 inch white stripe running down one side. Sent it to Acer for repair. They are tellling me that this was neglect. That I had to of damaged the lcd screen. The heat would not do this. I have read several articles about Dell having this same problem. Of course, Acer will not repair it, well for $700. I did not do any type of abuse, neglect, spill, drop nothing to this computer. It had to of happend due to the heat. What do you think.
    Scholar:
  • 176 Answers
Well if , the stripe u're talking about is a crack in the display, than it;s not caused by heat or electrical surge... If not, than u can go to a technical evaluator, and than if u have the time and money make an official complaint ....(if it's still in warranty..)...and recuperate u;re financial damage...
If not, just find a second hand display, and change it u;re self, it's easy !
Posted on Jan 19, 2008
Acer 53338 lap top got power but won't turn on
Remove main battery and try again, next sub out the ram memory one at a time and power up each time. If still unsuccessfull the DC jack in the laptop is the most likely problem, they often develop bad connections at the DC plug source causing all kinds of symptoms, the computer must be dismantled down to the motherboard level to address this.
May 04, 2012 | Acer Aspire 7520-5185 Laptop
As soon as I turn my PS2 Slim on, it shuts down within 3-5 seconds.
Check to see if the device is overheating- the symptoms sound like bad power adapter/dc charger board, overheating, or otherwise bad hardware failure. If so, you may need to see about a safety replacement from Sony (overheating = fire hazard)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 28, 2010 | Video Game Consoles & Games
My battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
Acer aspire 3680 won't turn on / Black out.
This line of Acer laptop has numerous power issues. If the laptop actually will not power you will likely need to perform some component level repairs. If it powers on but does not complete POST. (Meaning you dont see anything on the screen) Then you would want to begin by removing the center panel on the bottom case. Once removed locate your memory sticks and make sure that they are seated properly. Remove them and reseat them. Try to power the laptop again and see if your problem is solved. It is possible that if this does not work that the memory is actually bad and must be replaced. There are quite a few other things that can cause this. Memory is the easiest to repair. This failure can be caused by a defective CPU as well, but for the average computer user I would not suggest taking your PC completely apart. If you are comfortable doing so you will want to disassemble it, remove the logic board and use a test CPU to see if this solves your problem.
In case your unit actually doesn't power on it changes things. The first thing you need to check is the status of your AC adapter. If you do not have a voltage meter you would need to use a test adapter to elimiate that possibility. More likely the problem is caused by an internally broken DC connector. This happens very frequently and is a rather simple repair if you posses decent soldering skills. You can purchase one of these DC connectors from ebay for $2 or so. Disassemble the laptop, remove the two screws that attatch the DC board tp the main board. Desolder the DC connector and replace it with the new one. Sometimes this DC board will have been damaged from a power surge. In this case the entire power plane connected to the back pin of the DC connector will likely be shorted to ground. If this happens remove the old DC connector, cut off the back pin and solder and heavy gauge wire directly to the back pin. Run this wire around the DC board on the left side of the DC connected as you are looking at the connector fromthe front. On the other side of the DC board you will see 2 farite beads wired in parallel. They connect the shorted power plane to the next. Remove these two farite beads and run the wire to the contacts on the next power plane. This will bypass the damage to the DC board.
If the DC connector is the the cause for the problem. There is a pair of capacitors on the logic board that fail very often. To see them you will need to remove the heatsink assembly from the logic board. They are ceramic capacitors right next to the CPU socket. They are wired in parallel and may bot show any physical signs of damage. If you have a multimeter set it to test continuity and put both leads on eachside of the caps, if you hear a constant beep then the caps register as shorted. Remove them both from the logic board and repeat this process with them outside the circuit. If you touch the leads to each side of the caps and hear nothing, then the cap is good. If you hear the same continuous beep then the cap is shorted and is the cause for your power issues.
If these suggestions have not solved your issue, then the motherboard may still be repairable but will require an experianced technician to isolate the cause for the no power. Good luck.
Jul 13, 2009 | Acer Aspire 3680 Laptop
Westinghouse model WTV-11901 shuts off by itself
That is usually a bad power board, the TV can be turned on again after a while because the capacitors inside TV will discharge after some time. The part must be tested before replacement, as overheating can cause similar problems.
Try also leaving the TV unplugged from main overnight, and test the unit on a different AC socket.
May 15, 2009 | Televison & Video
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Any body can tell me the acer sevicing center in vishakhapatnam
Bad capacitors on the internal power board capacitor replacement is indicated
Feb 02, 2009 | Acer AL1715 17" LCD Monitor
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Sub amp clicking on and off rapidly
Usually, it's the DC voltage in the amp's output that's triggering the amp's protection circuitry. If some component parts change its value due to temperature (overheating), it sometimes causes the DC voltage to occur. Check components such as, capacitors, semi-conductors, etc..Hope you can pinpoint the problem part.
May 14, 2008 | JBL Northridge E 250P Subwoofer
Condensor motor turn very slowly.
I do believe you will find the Mother Board is the cause of your problem. I also believe your original motor was ok. The motor runs on DC voltage. There are 3 wires to the motor. The red wire is a sensor wire. The other 2 wires should provide 12 to 13 or so volts DC to the motor. If it is not the mother board is bad.
I hope I helped. supertechks
Mar 05, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Acer Aspire 3680 Laptop Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
