FixYa.com
Tags:
BenQ PB6100 Multimedia Projector
Projector shuts down after only a few minutes.
posted by kacheng on Jan 19, 2008
After somewhere between 10-30 mins of operation, the projector seems to turn itself off.
The projector will blank out and the red 'lamp' light blinks. The fan continues for about 30 seconds (which seems shorter than normal?) and when complete the orange 'Power' light goes on, indicating 'Stand-by' mode.
At this point, I can turn the projector on again and get another 10 minutes.
I have tried to clean out the unit - did I miss some important, easy to miss, vent?
I have just replaced the lamp, and though the image is brighter, this shut-off behaviour still occurs.
Is this temperature related?
Is this a problem with the projector itself?
Is my second lamp defective?
Thanks for any help you can offer.
Comment by kacheng, posted on Jan 21, 2008
I fiddled with the menu settings and turned the auto shut-off to zero.
I also reseated the lamp again.
One of these two things seems to have solved the problem for now...
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 28, 2008
Not Rated (0)
SPENCEMO
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
WHILE MY PROJECTOR WAS IN USE IT JUST SHUT DOWN,I THOUGHT IT WAS THE LAMP SO I REPLACED IT BUT AM STILL HAVING THE PROBLEM. I GET NO PICTURE AND THE RED LED LIGHT FLASHES. PLEASE HELP
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
DartVeiga
Rating: 74%, 4 votes
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Can you Help with these Multimedia Projectors problems?
Please tell me how to reset...
Please tell me how to reset... Answer This...
RCA to DVR
How can you connect a RCA... Answer This...
Maintenance Nec vt480
I need maintenance for my NEC... Answer This...
Preylahong NEC MT830+need help...
Hello, Marrie if you can help... Answer This...
BenQ PB6100
Mi proyector no tiene reconoce... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
