Question about Hitachi DV-PF2U DVD Player/VCR
CST.IN Light After turning on the DVD/VCR recorder, the "CST.IN" light begins to blink continuously and shuts off the power to the unit after about 5-10 seconds . You are not able to do anything as it has no power. With the power off, the light continues to blink. Thanks for any help, Bob
  • 12 more comments
  • SMP13 Mar 04, 2008
    I have the same problem, player keeps turning off after 5 seconds.
  • spency-wency Mar 11, 2008
    Yes I have the exact same problem. Is there any solution besides throwing it at the wall and then in the dumpster?
  • jamasister Mar 12, 2008
    same thing here
  • Anonymous Apr 02, 2008
    have same problem as BikerBob's CST.IN Light problem. Frank A.
  • golfuninmn Apr 04, 2008
    I have the same exact problem as described.
  • Anonymous Apr 26, 2008
    same problem here.
    tiledr@gmail.com
  • edge43 Aug 03, 2008
    I too have the problem with 10-sec power off then cst.in blinking.
  • blueacepa Nov 11, 2008
    Same exact thing, fixed it by letting a VCR tape load and then the DVD worked.
  • cindy122094 Mar 21, 2009
    Had the same problem and just tried this...and it worked
  • Anonymous Mar 24, 2009
    I had the same problem. I put a VHS tape in and ejected and it worked. But, later I put a tape in and it ate it- broke the tape.
  • Anonymous Apr 06, 2009
    I have the same problem, but my vcr will not take in a tape.
  • Anonymous Apr 27, 2009
    cst.in light but ther is no tape inside and cant put one inside either
  • ryanracer08 May 11, 2010
    mine did the same thing how do you fix it?
  • Don Rogers
    Don Rogers Aug 10, 2013
    I'm having the same problem. However there *is* a tape in the player. It won't eject, play, FF, rewind, anything. Just keeps shutting off. Aaaaaarrgghhhhh!
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Posted on Nov 15, 2008
I fixed mine by putting a vcr tape in the machine, it loaded and then my DVD starting functioning again. Don't know why but it worked.
Posted on Nov 11, 2008
Same problem here...and it was particularly annoying, as it was inhibiting my annual ritual of watching "It's A Wonderful Life" on Xmas day.
After about a half hour of figuring the mechanism out, I traced the problem to a small lever toward the front right portion of the VCR loading mechanism (near the power switch corner of the unit). It had apparently failed to release the last time that the tape was ejected. After releasing the lever manually (in hind sight, a good rap on the side of the box may have done the trick), everything is back to normal.
Note: when the unit is open, you need to tape over the LED sensors on either side of the VCR loading mechanism while troubleshooting, or else the external light will inhibit operation.
Posted on Dec 25, 2009
Press eject 5 times and try it again and it works
Posted on Nov 04, 2009
    New Friend:
The top two answers are correct, but in my case I had to take the cover off and I found that there was a very small belt rapped around two wheelies that was stuck and not turning. I just moved it a bit and got it unstuck. On another VCR I had I figured out that my grandchild had stuck some pennies in side. I opened it up took the pennies out and it worked fine. The strange thing is if the VCR doesn't work, neither will the DVD player.
Posted on Jan 13, 2013
I fixed this problem on mine today. I read the manual online and found that CST.IN light means there is a cassette in the VCR. Since I didn't have a cassette in the VCR at the time I suspected a problem with the VCR and attempted to take the unit apart to disconnect the VCR. With the cover off I powered the unit on and a wheel in the back came on until the machine shut off automatically as it has been doing. I was unable to disconnect the wires but after unscrewing most of the VCR mounting screws I tried powering on again and this time the wheel in the back shut off and the unit stayed on. I put everything back together (minus a few VCR mounting screws) and put the cover back on. My DVD player and TV controls work fine now. I put duct tape over the VCR since I don't plan to use it anyway, and I am happy.
I wish this was a better solution that I could say exactly what I did, but I can't. All I know is that it's the VCR that caused the problem and I rarely use mine anymore anyway. And I know nothing about electronic, but I figured that taking the unit apart was better than buying a new DVD player right now. If you feel the same way I suggest you give it a try. Good luck!
Posted on Aug 04, 2008
    New Friend:
My Symphonic VHS DVD players does the same thing. When I put in my VHS-C adapter (with VHS-C cassette installed) the system shuts down. To remove, I have to turn the power back on. Really want to watch these VHS-C cassettes...
Posted on Jul 31, 2014
    New Friend:
I called customer service & was told that I had to get it serviced or buy a new one. I took the back cover off & nothing was broke, the CST.IN light still blinking & my 14 yr old son comes in & I explain that I need to put a VHS in to get it to work since it thinks a tape is in & pushed the eject button & omg it worked, I'm so happy. So try the eject button first. I'm now watching a movie.
Posted on Jul 21, 2013
I think there are two light sensors that detect when a tape is in the VCR. When I took mine apart, the two green LED looking sensors are on each side of where the tape would rest if it was fully installed. I pushed one inward and it started whirring, then shut off. If the sensor has failed, then the logic will always fail and shut down the VCR. I don't know of a fix for this and may just chuck the whole thing.
Posted on Oct 31, 2008
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
The cst.in function on my dvd/vcr is blinking and because of it, i can't work my dvd/vcr. What can i do to fix the problem?
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one!
Jan 16, 2011 | Emerson EWD2202 DVD Player/VCR
I have a Sharp DV-RW550U VCR/DVD Recorder
check for bad capacitors (make sure its top is not bulged), check for bad step down transformer on unit. one or more of these may need to be replaced, if you are replacing faulty capacitors, make sure they are of same uF ratings, the unit will accept a +/- tolerance difference of 10%
Jul 07, 2009 | Sharp Televison & Video
VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
co6bg@yahoo.com
Feb 02, 2009 | Emerson EWD2202 DVD Player/VCR
CST In light is flashing green
I had the same problem. Aren't three-year-olds great? Mine had jammed several clothing tags into the VCR slot. Clearing them out didn't solve the problem, but I then took the outer case off (with power disconnected of course) and verified that there was no physical damage to the tape heads and that everything internally was clear. I put the case back on, and everything's back to normal.
Jan 06, 2009 | Sylvania SSD803 DVD Player/VCR
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Sv2000
I had a similar problem, particularly when trying to use the DVD recorder, and when I turned on the unit it made a loud rapid clicking sound, and then immediately shut off. It appears to have been the VCR section of the unit (which I rarely use) that was causing the glitch, and the pragmatic solution was to simply leave a blank VCR cassette in the machine all the time. Then I was able to use the DVD recorder without the noise and shut-off problem. (posted 2009-07-22)
Jun 23, 2008 | GoVideo DV1030 DVD Player/VCR
Won't ower up
Unplug unit for about 20 minutes then plug back in and see if it works
Aug 27, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hitachi DV-PF2U DVD Player/VCR Logo
5,919 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
