Question about Samsung PCN5425R 54" Rear Projection Television
Pusheed in sreen and can't converge red lign
The screen has shrank in the middle and is wider at the corners, I also can,t converge the red line, please help
  • 4 more comments
  • romus Jan 19, 2008
    I also have a doublevision picture on my TV
    i hope this helped
    I am relieved its nothing serious, Thanks for everything, if possible can You let me know where i could get hold of the ICs ?
  • romus Jan 25, 2008
    Hi I have just replaced the two ICs that were in the TV. When I turned the TV on, I have experienced the same symptoms. The lines on top and bottom are curved, there is a triple vision and mostly the screen appears reddish color. I still can't manually converge the red line, only blue I have control over. Please give me your feedback on this problem, I am not giving up on this so easily - at least I have brushed up on my soldering skills.
  • romus Jan 28, 2008
    Hi I am not sure if You got my message that I wrote last Friday. Basically I have checked almost all resistors and I am getting a reading from every one I checked. I didn't see any opened ones but who knows if the reading from them is the correct amount of ohms as it should be. I send you a picture of something I have found on the back of the board, probably a fuse, that is the only thing that doesn't give me a reading. Please let me know what You think I should do.
    Thanks for reply, I have changed the two ICs and the I have checked most of the resistors but not one of them were open, I am still getting the triple vision and curved sides, any solutions?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
  • Cary Farah
    Cary Farah Jan 28, 2008
    Samsung parts for convergance problem
    http://www.partstore.com/Part/Samsung/Sa...
  • Cary Farah
    Cary Farah Feb 01, 2008
    have the board checked out at ptscorp.com
  • Samsung Master
  • 8,617 Answers
Sounds like the convergence amp Ics are faulty they will distort the picture and you wont have any control over convergening the color back into alignment. Can you post a picture of what your screen looks like?
Posted on Jan 19, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 19, 2008
    Its not uncommom for the picture to have double even triple images on the screen when the convergence ICs go out. Because each tube projects it own image onto the screen. The convergence amps control this projection electronically. So when the ICs go out the image isnt contrrolled any more so you will get a distortion in the picture and it will look as if there are 2 sometimes 3 pictures appearing on the screen and your picture can bow in from the sides and the top and bottom.These ICs run at high temperatures they fail usually evry five years or so. They are fairly inexpensive. Its the tech fees that shoot the price of repair up. The ICs themselves usually cost about 10.00 each you have 2 of them in your set.
  • Sonny Berry
    Yes you will have to look inside your TV for a large metal heat sink. they will be attached to that. They are black and will have a white number stamped on them suchas STKXXX-XXX write this number down that will be the number you order and you can get them at the following link. Be sure to purchase some heat sink compound with your ICs. here is the link
    http://electronix.com/
  • Sonny Berry
    Sonny Berry Jan 25, 2008
    Check the resistors right next to the ICs some times when the ICs go they will take out a couple resistors. Usually right next to the hea sink. Just check them to see if any are open.
Can't get digital array ligned up,I went by the operating guide got the blue to line up but the red won't move.
Please replace convergence output chips in tv to solve the problem. It requires good soldering skills/ expertise and click to buy convergence repair kit for this tv that has all required parts and instructions.
Hope this will help.
Thanks.
Jun 11, 2011 | Hitachi 60FX20B 60" Rear Projection...
How can I raise the lines to the of the screen. Out of Focus.
You can't adjust because the convergence correction IC' are bad. The 3 you mention Buttons are probably for focus (electronic) and they won't help your problem. If you moved the CRT top lenses they can be re-adjusted and only affect focus (mechanical).
Your main issue is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 05, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
I have a panasonic 47" widescreen about 5 years old. Recently turned it on and all 4 corners are missed aligned and a faint line going through the middle. Tried setting the convergence with all of them...
Yes, the convergence output IC's have gone bad. They need to be replaced. This is a very common problem with all projection tv's. It is the job of those outputs to properly align where the red, green and blue beams land on the screen.
Jun 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Picture double, Color messed up
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 02, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Thin red line down the middle of screen
Enter muye 1 / 8 /3
it puts you into convergence mode and clears out all bad magic foces data.
then run perfect focus to save new data.
hope this helps
daniel
Jan 08, 2009 | Akai PT4298HD Rear Projection Television
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Red Green Blue Across The Screen
Yes, especially big screen. It sounds like convergence is out of lign. Try menu and straighten out, wait until set is warm first.
Dec 06, 2007 | Sony KP-46WT520 46" Rear Projection...
Warping
If this is a projection tv then replace convergence amps. and resistors in the area also look for open fuses.
Sep 05, 2007 | Philips 55PP9352 55" Projection Television
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
