Question about LG RU-27FB30C TV
Hot over heats
Hot st2310hi shorted replaced with nte 2642 new hot over heats no hv.
    Genius:
  • 1,067 Answers
Add more fans they sell those on ebay 4 pack that runs off ac outlet suck that hot air out faster
Posted on Jan 19, 2008
Model 721.64282 microwave/convection oven - microwave not heating and making a loud noise. convection oven works
No heat but otherwise normal operationA shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
Oct 21, 2010 | Kenmore 63663 Microwave Oven
Tip
Troubleshooting Guide
  • Problem: Totally dead oven.
    Possible causes:
    1. No power to outlet (blown fuse or tripped breaker or GFCI).
    2. Blown main fuse - likely due to other problems.
    3. Open thermal protector or thermal fuse.
    4. Defective controller or its power supply.
    5. Clock needs to be set before other functions will operate (some models).
  • Problem: Totally dead oven after repair.
    Possible causes:
    1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
    2. Any number of screwups. :)
  • Problem: No response to any buttons on touchpad.
    Possible causes:
    1. Door is not closed (some models).
    2. You waited to long (open and close door to wake it up).
    3. Controller is confused (pull plug for a minute or two to reset).
    4. Defective interlock switches.
    5. Faulty controller or its power supply.
    6. Touchpad or controller board contaminated by overenthusiastic cleaning.
    7. Defective/damaged touchpad.
  • Problem: Oven runs when door is still open.
    Possible causes:
    1. Damaged interlock assembly.
    2. Cooling fans (only) running due to bad sensor or still warm.
  • Problem: Oven starts on its own as soon as door is closed.
    Possible causes:
    1. Defective triac or relay.
    2. Controller is confused (pull plug for a minute or two to reset).
    3. Defective controller or its power supply.
    4. Touchpad or controller board contaminated by overenthusiastic cleaning.
    5. Defective/damaged touchpad.
  • Problem: Oven works but display is blank.
    Possible causes:
    1. Defective controller or its power supply.
    2. Broken display panel.
    3. Oven needs to be reset (pull plug for a minute or two to reset).
  • Problem: Whacked out controller or incorrect operation.
    Possible causes:
    1. Previous or multipart cook cycle not complete.
    6. Defective sensor (particulalry covection/mirowave combos).
  • Problem: Erratic behavior.
    Possible causes:
    2. Bad connections in controller or microwave generator.
    3. Faulty relay - primary (or HV side, much less commonly used).
    5. Bad contacts/connections on mechanical timers. Intermittent fuse.
    6. Power surge at start of cook cycle confusing controller.
    7. Microwave (RF) leakage into electronics bay.
  • Problem: Some keys on the touchpad do not function or perform the wrong action.
    Possible causes:
    1. Touchpad or controller board contaminated by overenthusiastic cleaning.
    2. Defective/damaged touchpad.
    4. Faulty controller.
  • Problem: Microwave oven does not respond to START button.
    Possible causes:
    1. Defective START button.
    2. Faulty interlock switches.
    3. Door is not securely closed.
    5. You waited too long - open and close door to wake it up!
  • Problem: No heat but otherwise normal operation.
    Possible causes:
    1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
    2. Bad connections (particularly to magnetron filament).
    4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
    5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
    6. Defective HV relay (not commonly used).
  • Problem: Timer and light work but no heat, cooling fan, or turntable rotation.
    Possible causes:
    1. Defective (lower) door interlock switch or door not closing fully.
    2. Faulty relay or triac.
  • Problem: Fuse blows when closing or opening door:
    Possible causes:
    1. Defective door interlock switch(s).
    2. Interlock switch knocked out of position.
    3. Misaligned door.
  • Problem: Loud hum and/or burning smell when attempting to cook.
    Possible causes:
    1. Shorted HV diode, magnetron.
    2. Burnt carbonized food in or above oven chamber.
    3. Shorted winding in HV transformer.
    4. Frayed insulation on HV wiring.
  • Problem: Arcing in or above oven chamber.
    Possible causes:
    1. Burnt carbonized food deposits.
    2. Exposed sharp metal edges.
  • Problem: Fuse blows when initiating cook cycle.
    Possible causes:
    1. Defective interlock switches or misaligned door.
    2. Shorted HV capacitor.
    3. Shorted HV diode.
    4. Shorted magnetron (probably won't blow main fuse but HV fuse if used).
    5. Defective triac.
    6. Old age or power surges.
    7. Defective HV transformer.
    8. Short in wiring due to vibration or poor manufacturing.
  • Problem: Fuse blows when microwave shuts off (during or at end of cook cycle).
    Possible causes:
    1. Defective triac (doesn't turn off properly).
    2. Defective relay.
    3. Shorting wires.
  • Problem: Oven heats on high setting regardless of power setting.
    Possible causes:
    1. Faulty primary relay or triac or HV relay (not commonly used).
    2. Faulty controller.
  • Problem: Oven immediately starts to cook when door is closed.
    Possible causes:
    1. Shorted relay or triac.
  • Problem: Oven heats but power seems low or erratic.
    Possible causes:
    1. Low line voltage.
    2. Magnetron with low emission.
    3. Faulty controller or set for wrong mode.
    4. Stirrer (or turntable) not working.
    5. Intermittent connections to magnetron filament or elsewhere.
    6. Faulty primary relay or triac or HV relay (not commonly used).
  • Problem: Oven heats but shuts off randomly.
    Possible causes:
    1. Overheating due to blocked air vents or inoperative cooling fan.
    2. Overheating due to bad magnetron.
    3. Bad connections in controller or microwave generator.
    4. Faulty interlock switch or marginal door alignment.
    5. Faulty controller.
    6. Overheating due to extremely high line voltage.
    7. Stuck stirrer fan resulting hot spots detected by sensors.
  • Problem: Oven makes (possibly erratic) buzzing noise when heating.
    Possible causes:
    1. Fan blades hitting support or shroud.
    2. Vibrating sheet metal.
    3. Vibrating transformer laminations.
    4. Turntable or stirrer hitting some debris.
  • Problem: Oven light does not work.
    Possible causes:
    1. Burnt out bulb :-).
    2. Bad connections.
  • Problem: Fans or turntables that do not work.
    Possible causes:
    1. Gummed up lubrication or bad motor bearing(s).
    2. Loose or broken belt.
    3. Bad motor.
    4. Bad thermostat.
    5. Bad connections.
on Mar 30, 2008 | Kenmore 80412 Microwave Oven
Hi, I have a SHARP Microwave Model R398F. Its less than a year old. The display and timer work fine but does not heat up. Can you please let me know what the problem could be. Thanks Js
If the operation is otherwise normal with the exception of heating food, common causes include; (to diagnose requires discharging of the HV capacitor) if you are inexperienced with working with HV I suggest seeking professional help.
Open thermal protectors or thermal fuses.
Open HV Diode.
Open HV capacitor
Defective HV relay
Shorted HV diode
Replacement Magnetrons (the most likely cause if not charring or defective components are found when troublshooting the small parts, can typically be had for around $45.00 just do a web search for your model number.
Good Luck
Sep 07, 2010 | Sharp Microwave Ovens
My lakewood high speed floor model HV-21T stopped running. After shutting off it started running again but shut off again and this time the motor and cage was extremely hot.Also are new motors available on...
Try replacing the "start-run" capacitor. It is the rectangular black box mounted on a tab next to the motor inside the cage, two wires attached (cut them close as close to the capacitor body as possible). Other symptoms include not moving at all with a hum, and getting very hot. The capacitor is a 5% tolerance 8 microfarad rated at 250vac. It doesn't have to be the exact form factor but it does have to be heat rated at or above 70C per design parameters of the fan.
WARNING! Make sure to protect the leads properly because this capacitor is connected directly to the power mains during operation. If one of the leads electrically shorted against the fan housing or cage could cause a catastrophic failure of the fan, and possibly a fire, and possibly give a nasty shock to whoever was switching on the fan at the time.
-Brandon
Aug 22, 2010 | Lakewood HV 18-c Floor / Box Fan
Just replaced the magnetron in my Panasonic NN-S543BFR. I still don't get any heat from my oven. Everything works as set but still no heat in oven. Need suggestions on repairs.
When you say "Everything works as set" do you mean the microwave appears to function properly, but then doesn't heat?
If the magnetron is new, then the magnetron must not be receiving the required high voltage (2000V or more) from the HV circuit. Make sure you've got 120V to the PRIMARY (don't attempt to measure secondary voltage of the HV transformer without special equipment) of the HV transformer. After that check the HV capacitor and diodes. If these components test OK, then either your HV transformer is bad or your new magnetron is faulty. My experience is that the problem is usually in control circuitry, preventing 120V to the HV transformer, or opens/shorts in the HV components (diodes and capacitors).
Mar 15, 2010 | Panasonic NN-S543BFW Microwave Oven
My emerson micowave mw8119sb blow the fuse, I replace with a new one same rating, it turns on but when I put something for heat it blew the fuse again. Any help! Thanks!!!
Could be a short in the HV system for the magnetron--usually the HV diode. Another possibility is the metal stirrer fan in the waveguide above the oven cavity may have a shorted bearing (plastic). The short occurs internally within the bearing.
Aug 01, 2009 | Microwave Ovens
Model JVM1860CF001 not heating...
If you feel comfortable doing so, you may want to check the capacitor. Burning odors however are usually caused by either the magnetron or HV transformer.
Nov 09, 2017 | Microwave Ovens
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Hot overheats
If this is your hori out put it means you have a bad flyback transfomer.
Jan 19, 2008 | LG RU-27FB30C TV
Powering on and off instantly
You either have a short in the unit somewhere, shorted high voltage section or a bad power supply. The most likely culprit is the high voltage section. If you are familiar with television repair, safety and good with a DMM and soldering iron you should be able to fix it. Check the horizontal output transistor (large transistor on the heat sink around or near the flyback. flyback is generally on the right side of the board and has a large red wire coming out of the top and going to the HV divider block.) If the transistor checks shorted, replace the transistor and flyback. Check all associated resistors and semis for any problems and replace anything out of spec. This should solve your problem. I have seen units with a bad HV block too so you may have to replace it also. If the HOT checks OK or replacing the HOT, flyback and HV block doesn't fix your unit you may or may not have the skills to troubleshoot the power supply and/or look for shorts in the unit. Certainly any charred components would be suspect. If you are not qualified to look any further you will have to have a qualified repair tech look at your unit. Good luck and be safe.
Jul 15, 2006 | Toshiba TP50H50 50" Rear Projection...
LG RU-27FB30C TV Logo
44 people viewed this question
Computer Repairing
Computer Repairing
