Question about Onkyo TX-SR803 Receiver
NO output sound
Everything working fine but not sound to the speakers; yesterday was a general power interrupted while a storm (over voltage when returned ??
Lightning damage ??) I'm not sure that was the really reason of the malfunction because there were a lot of other electronics in the same line and they are working fine (Xbox, TV, DVD player)
I opened the chassis and check all fuses and they where all ok
All the function seem on the display work fine, only no sound output
When I turned on, it makes the usual relays clicks sound.
I test second zone and pure audio but nothing
I test with various sources: FM tuner, two different CDplayers but nothing!
PLEASE HELP ME!!!
  • 1 more comment
  • Jeanne0704 Feb 12, 2008
    Onkyo HT-R510....sound just stopped coming from speakers. All other displays working properly. The system worked perfectly one moment and the next, it had no sound.
  • kjsh Jun 27, 2008
    I have exactly the same problem. It may have also occured after a lighting storm. No problem with any of the other electronics and unit was on a surge protector. I tested everything I know how to test, did a system reset, unplugged, etc. No sound.
  • jcbear Aug 12, 2008
    I have had the same problem. However, if I continually power it off and back on, it eventually does pick up the sound. I've disconnected everything from it so I'm only using the tuner. It drives you crazy to have it happen with the video feeds connected.
SOURCE: reciever shutting off
To: "mrlong86"
This idicates problem with output circuitry. Have unit checked out by pro/tech
To: "flyhigabe"
You indicate you have speaker spliced in with another(?)
This changes the impedence which may be too low for amp to handle. It may cause amp to shut down to stanby.
Posted on Apr 27, 2008
  • 319 Answers
SOURCE: Lost Audio via HDMI
Check the pins on HDMI cable at both ends. Check for bent or broken pins. If all are OK, re insert firmly. Retry
Posted on May 07, 2008
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
  • 17 Answers
SOURCE: Zone 2 speakers only work with the tuner - no
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Posted on Jul 10, 2009
  • 118 Answers
SOURCE: Problems with optical input
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Posted on Dec 08, 2009
With the Mackie PPM608 Mixer, our passive speakers aren't working. We use CVi-252s, but I'm sure it's an issue with the mixer rather than the speakers.
Get a plug cable and work the plug in and out of all INSERT or BYPASS jacks. These get rusty and interrupt signals.
If that is a no, open up and check power supply voltages and all cable connectors, might have been vibration and something got loose...
PEACE---
Jan 31, 2016 | Mackie PPM608 Professional Powered Mixer
Hi guys. Having a problem with my NAD T163 Surround Sound Decoder. Popping in front left and right speakers when changing audio selection. Works well other than that. Please give me some suggestions w
Could be DC voltage on the speaker output line, but this will generally keep your receiver audio output turned off completely. Could be a bad muting transistor or microprocessor IC(computer within your NAD). If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com.You may contact me there. Thank you..
Jan 01, 2014 | Sony TA-E9000ES Amplifier
Just performed a new install on this. Everything powers up and works fine, including the power antenna. Followed set up instructions including selecting speaker output but no sound at all? Radio station...
It sounds like you may have the negative and positive polarity wrong usually to the speakers. I suggest to use black for negative and red for positive so that each speaker is correct. Speaker wire is good but for self installs its a common mistake.
Oct 23, 2013 | Kenwood KDC-HD455U
Dv7 subwofer is missing so speakers and headphones dont work. Do i need a new subwofer?
Generally speaking, sub-woofers are not built into notebook computers, as most sub-woofers would not fit. However, there are generally speakers, and there tend to be problems with the audio drivers in most cases if there is no sound for both speakers and headphones.
Within the notebook, there should only be two speakers. If they're missing, did you buy this used or refurbished? If someone just yanked out the two speakers and carelessly cut or handled the wiring improperly, then this could interrupt the headphone bypass cut-off.
I know you mentioned you'd already verified everything appeared to be working properly, and in some cases updating drivers or uninstalling and re-installing them has a positive result. For the obvious, which I've also forgotten to check sometimes, is whether the output is muted within the volume control and mixer.
In case you hadn't already checked out these, here are a few links you may find useful:http://h10032.www1.hp.com/ctg/Manual/c01613382.pdf
http://h10032.www1.hp.com/ctg/Manual/c01613127.pdf
As always, the more complete the information up front, the better the potential for a solution. I hope this helps!
Feb 12, 2012 | HP Pavilion dv7-1245dx Notebook
Kenmore Microwave model 721.80019 does not heat
Hi
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. As there was power loss due to storm so I believe it could either be the the high voltage circuitry, or the circuit board . To resolve this problem, you need the assistance of a qualified appliance repair technician.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Jun 07, 2009 | Kenmore Microwave Ovens
Can not get any TV Channels, but works fine on CD or DVD playback(movies)
Hard to pin-point the problem without examing the set; but, it sound like a tuner problem. First thing to do is to check if your tuner is getting the adequate voltage supplies - generally speaking there should be a pin with 33 vdc, one with 12vdc, and one with 5 vdc. If this is not the case, then it is a power supply problem. If your are getting the appropriate voltages, then check for crack solders on the input and outputs of the tuner. I did one yesterday, were I had to open the tuner and resolder the ICs on the PCB.
Nov 04, 2008 | Toshiba Televison & Video
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
barneyluc
Oct 03, 2008 | Pioneer Audio Players & Recorders
My monitor does not turn on
there is power problem  in your monitor.check the fuse,regulator,and horizontal output transistor
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Onkyo TX-SR803 Receiver Logo
57 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
