Question about Stoves Newhome ECH600MXa Electric Kitchen Range
Help! i need the manual for this appliance. i need to set the timer
Can you help me
Kitchen.manualsonline.com, might help!
Posted on Jan 19, 2008
6ya staff
SOURCE:
I have an old "Intermatic Time-All." I no longer
Most time-all timers have two different trippers on dial.
Push down and rotate tripper to desired ON time and OFF time.
Then manually rotate dial until current time lines up with a mark or arrowhead.
To replace timer with new one:
Buy TN311c with 3 sets of on-off trippers that push onto dial, and 3-prong outlet.
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
Buy TN111c with 2 sets of on-off trippers, and 2-prong outlet
http://www.amazon.com/Intermatic-Appliance-Security-TN111C70-Settings/dp/B00002N5FI/ref=pd_cp_hi_3
Aug 09, 2011 | Solar Intermaticlamp & Appliance Timer...
I'm using the woods 59200 mechanical timer to automatically open and close a chicken coop door. I can't for the life of me figure out how to set it. Help!
Woods 59202 is 7-day analog VACATION timer and cannot be set.
Vacation timers are preset to turn on-and-off at random times so it looks like somebody is home when you are away.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59202
You might want the 59201 analog timer which can be set for on-off times over 24-hour period. Minimum on-off is 15 minutes.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
If you need a 7-day timer, buy a programmable instead of analog. Wooods 59377 or Intermatic DT630 heavy duty
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU
If you have analog plug-in timer, open following link to see how to set timers:
http://waterheatertimer.org/How-to-set-timers.html
Jul 05, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
Lost my instructions on how to set timmer.wher can i or how can i get instructions?
You posted under Stanley 38439 timer.
I don't have a manual for this timer, and can not find one, but instructions are simple.
1) If you need instructions, nettizer posted free instructions on following fixya link
http://www.fixya.com/support/t4853106-purchased_lampmaster_38439_timer_need
2) If you need a manual for your website, buy one at Amazon for $10 plus shipping.
http://www.amazon.com/Stanley-38439-LampMaster-Appliance-Indoor/dp/B0020ML72G
After receiving timer manual, please scan it into pdf format and post it on your website for free, and then add a comment to this thread with web address of manual. That way, next person who needs a manual can benefit from your generosity.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Stanley 38439 LampMaster Lamp and...
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 29, 2011 | Hampton Technologies Brinks Timer
How do i set this time to come on and go off daily
I believe the First Alert timer is same as GE 15151 vacation timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
If this is not your timer, then add a comment.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 20, 2010 | First Alert Tm261 7Day Vacation Timer
How do i set this timer to come on and go off daily?
A vacation timer turns on-and-off randomly to give the appearance that somebody is home.
I lost my instructions and I need to set the timer.
You posted under Woods 59200 timer which is plug-in dial timer with 2-prong outlet 1250 watts
50 mini-bulb Christmas string is 25 watts.
If this is not your timer, add a comment.
You can see Woods timers and manuals at:
Woods 59200 manual:
http://waterheatertimer.org/pdf/Woods-59200.pdf
Dec 05, 2010 | Woods 59200 Lamp and Appliance Timer with...
I need the steps for setting the timer function
Link shows the Sylvania indoor timers
http://www.hardwareinnovations.com/prodshelf.asp?dept_id=1007
Click on photo of your timer
Next page opens
Click on the word 'manual' to open a copy of your manual
If you have the AS140, the link below goes to that manual
http://www.hardwareinnovations.com/pdf/SA_130_IB58572_02.pdf
The timer comes with a replaceable battery.
The battery lets you program the timer before plugging timer into wall.
If you need help with instructions in the manual, answer back and I will help.
Oct 24, 2010 | Sylvania 15 Amp Zip Set Digital Lamp and...
Time setting does not function. Clock doesn't cycle. Manual on/off functions and appliance turns on
As a general rule, if the timer clock does not rotate on plug-in-timers and in-wall-timers, then the timer has gone bad and needs to be replaced.
A larger box-type timer that attaches to the wall is different. For many of the box-type-timers, that are mechanical and not electronic, the clock motor can be replaced.
Oct 17, 2010 | Solar Intermatic Air Conditioner &...
I need immediate help with my Panasonic Bread Machine. I need to know how to set the timer for the bread to be ready at 6:00 AM. I would like to get a copy of the manual.
You didn't give the model number but here is the best I could do. Actuall many timers run the same way, so this may answer solve your problem
Hank
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Kitchen-Appliances/Bread-Makers/model.SD-YD250
Oct 08, 2009 | Kitchen Appliances - Others
Stoves Newhome ECH600MXa Electric Kitchen Range Logo
1,740 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Greg Bernett
Greg Bernett
Ismael Rodriguez...
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
