Question about RCA 32F531T 32" TV
RCA Model # F19261
Dear By mistake, i did pressed some buttons, because of that, when I turned on my TV, It says unlock.
Please help me, I will appreciate your help.
Thanx
Kris
Try pressing the display button on your remote for a few seconds, should unlock it.
Posted on Mar 02, 2008
6ya staff
SOURCE:
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
Cannot find the audio/video in connections on an rca f19261 tv.
The only solution to your problem if the tv does not have rca inputs is to optain a converter thant converts coax to rca........ but if the tv has an svideo input that would work as well with a mini to mini audio plub
Sep 05, 2011 | RCA F19261 19" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
I locked up my set by mistake need to unlock it and adjust channel for directv I lost my remote use the front keys which caused initial problem tried to adjust volume hit channel key
Hello
Tounlock your TV you surely need its remote control. Try to get it from somewhere, from any one of your friends, who own the similar model of TV, or buy it from RCA. After getting it try the following. You can unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
I made a mistake and hit the menu button and lock my tv the red lite is on nothing wont show tv wont com on
you need the unlock code to the tv try pressing menu and 99 at the same time it should reset and let you in type new pass word (write it down) and your set
hope helps
Jul 07, 2010 | RCA TruFlat 27F520T 27" TV
How do i plug a dvd player into a RCA television model F19261?
The same way you hook it up to an RCA television model F19262
Dec 06, 2008 | Televison & Video
RCA 20F420T FPA lock
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Jan 21, 2008 | RCA 20F420T 20" TV
Unlock my tv
i have problem on my tv i dont know how unlock
Nov 11, 2007 | RCA 32F531T 32" TV
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
I forgot the password to unblock channels. what do i do?
If My memory serves me correctly LOL just kidding!! On Most every RCA there was no magic reset or button . The eeprom IC had to be changed! This little 8 pin package IC is solderd into place and its not a job or the experimenter or handi man. Get a pro to replace the IC and have him(the tech) install a socket on the iC just in case you forget again.. Good Luck
Aug 08, 2006 | RCA F19261 19" TV
RCA 32F531T 32" TV Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
