Question about Roper RES7646KQ Electric Dryer
Heats up but not drying!!
Our dryer will heat up but it will not dry, everything stays hot and damp and soggy. After about ten hours of tumbling things will dry but thats to long to run it continuously. There is nothing clogging the vent and exhaust areas. It seems to work when we prop the door open, but then fuzz goes everywhere. The fuzz collector does not collect anything either. Does anyone know what could be wrong? There is no electricity or breaker problem, that stuff is fine.
  • 3 more comments
  • Anonymous Jan 26, 2008
    i live in a t
    mobile i have the same proble would it be that the vent running out side proper
  • bunnymom2k Jan 27, 2008
    well it is an electric dryer, how can that cause it to catch on fire? The dryer is 5 years old. Thanks
  • pleasfixa Mar 09, 2008
    my dryer runs fine at times but then it dries but the clothes are soggy and damp. I have to dump the water out of the hose for it to dry proper. I don't think this is normal. what should i do?
  • sardis Apr 07, 2008
    My dryer will not dry. It gets hot, but clothes stay wet and hot. I replaced the vent system and checked everything including cleaning out the dryer itself from any lint. Please help.
    It is a Roper by whirlpool.
    lweaver
  • robert samples May 11, 2010
    how old is this drier
  • 447 Answers
The Vent is CLOGGED !!!!!!!!!!!!!!!!!!!!!!
TRUST ME
There is no other possible reason for the dryer taking a long time to dry other than vent restrictions or just poorly built duct.
DO NOT RUN THE DRYER WITH THE DOOR OPEN
Not only can it damage the dryer it can catch fire!!!
Posted on Jan 19, 2008
    President:
  • 1,314 Answers
The best way to find out if its a vent promblem is to run a load with the vent off see if it does right reply and ill tell you the easyist way to fix the vent
Posted on Jan 27, 2008
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Heat does not go on and stay on clothes tumble but are still damp they never completely dry in 70 min.
sounds like a venting problem, check vent tube for restrictions, you can take the tube off and run the dryer, should have hot air blowing out, if you do then it is the vent tube if not then you will have to clean the inside of the dry out with a vacuum. Good Luck Tim
Oct 25, 2010 | Kenmore 73952 Gas Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Tumble dry is heating but takes forever to dry
check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
Roper RES7646KQ Electric Dryer Logo
106 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
