Question about Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL low output and "motorboating"
My Uniden Pro510 XL CB radio has reduced rf output. As the transmitter is held on the output starts out at about half power and slowly decreases. Also it will go into a "motorboating" condition when modulated or when the power level decreases and it is keyed on again. I have replaced several of the electrolytic capacitors, but the problem persists. It is transmitting and modulating on the proper channels, and the receiver seems to be normal. Hope one of you techs have had experience in working on this model. Thanks. Bob W.
  • 3 more comments
  • rdw0yoc Jan 19, 2008
    Thanks for your input. I should have stated that as far as I can tell this radio is virgin. It does have the original Uniden mic, and I have heard of Rife/bare systems, but I have no idea what that is. The audio amplifier is the original TDA1905 IC --- and something I also neglected to mention is that I have removed the 470MFD modulation output capacitor to help isolate the audio amp from the rf stages. (It didn't help). Audio output from the amplifier looks normal to me -- and clips at 5 volts in both directions at the amplifier output pin (1). The voltage on mic pin 3 is about 8vdc, and the unit continues to motorboat with the mic disconnected and pin 3 grounded. Again --- the RF output is very low and fading with time --- maybe a half watt, as read on my BIRD Thruline watt meter. Oh yes -- you mention VR2 -- isn't that just the output power level indicator calibration? There are just two segments showing on the front panel rf out indicator. What is the function of Q6? Is there a good schematic or service manual anywhere for this radio? I will continue replacing electrolytic capacitors at this time. Thanks again for the assistance!
    Good thought --- but I have not been able to detect any obvious bad solder joints --- but I will continue to be on the lookout for them. Thanks for replying!! Bob W.
    Thank you for the advice on solder joint examination. The CB radio belongs to my son, who bought it on eBay I believe. As to it's age, the circuit board says Copyright 1987 -- PA-375AA, and the serial no. of the radio is 55095536.
    Thank you VERY much for the schematic! I will proceed to check the voltages that you list, etc. The reason I started replacing electrolytics is because I suspected a "motorboating" issue, and that is generally caused by insufficient powersupply bypassing. I find that old electrolytics have often dryed up and can cause such a problem ---- However, maybe my description is faulty -- what I am calling "motorboating" is pulsing RF output -- it starts out with clean CW, albeit at low RF output, then decays and starts rapid bursting --- a few short bursts, a longer burst, and then a repetition of that --- etc. On a receiver it sounds like "motorboating". I will see if I can figure out how it works now that I have a diagram --- Thank you for the support!!! Bob W.
    YEA!! --- IT'S FIXED --- And do I feel stupid!! Would you believe it that all that was wrong was a bad fuse holder??? The 13vdc supply was falling to below 8v when the transmitter was keyed on due to a corroded connection in the fuse holder! Now why I didn't check the primary power supply AT THE radio I cannot answer! My heartfelt thanks go out to the great support you gave me toward trouble-shooting this CB radio! Thank you again!! Bob W.
    Brigadier General:
  • 6,966 Answers
Based on your post/description, I am assuming that:
1. The standard Uniden microphone that came with the radio has not been replaced with a power microphone;
2. The amplitude modulation method (transformer) is not modified;
3. The Power Output has not been modified;
4. The radio is not being used in a Rife/bare system.
Your posted problem may be caused by:
1. Mic. You can verify if your mic is causing the motorboating by grounding pin#3 to transmit without any input audio/mic connected; with pin#3 grounded and no audio in, determine if you still have the motorboating problem. If no then chances are its the mic, if yes, then its internal to the radio;
2. Audio amplified IC and/or its associated components. Check the audio amp is TDA1905, capacitors C50 to C58;
3. AMC (amplitude modulation control). VR2, Q6 likewise check the Limiter Q5.
In some versions, a microphone with an Electret Condenser Microphone Element is used. This type of mic uses 2.8~3.3 volts DC from the radio. These versions may use the audio line (pin#2 in a wire pin mic plug) or a separate +3V mic power (in a 5 or 6 pin mic plug). Motorboating then may be further caused by the dropping resistor that has gone up in value or by the capacitor after the resistor that has lost its capacitance along the +3V line. Indication low or no +3 in pin#2. In some instances, the +3 goes down when talking into the mic.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 19, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Jan 19, 2008
    for Cerfer39,
    It would seem that you have posted while I was composing my reply. Sorry to have stepped in.
  • Louie  Role
    Hi again,
    Appreciate the quick reply/post. By removing C51 you really have elimated the audio (RX/modulation) as the possible source of your problem. My bad on the VR2, you're right it being the RF meter adj, was thinking of something else. Q6 is modulation audio limiter but as earlier stated should not be considered.
    Concentrating on the lo power, pls verify that:
    1. the collectors of Q501 & Q2 should have +13VDC, Q3 11.2 & Q4 6.2 on TX;
    2. the emitters of Q501 & Q2 should read zero, Q3 2.5 & Q4 2.4 on TX;
    3. the emitters of Q 3 & 4 are not directly grounded but passes through resisors R54 & R57;
    4. the +6.2 on the collector of Q4 is limited by Q5 who in turn is supplied by 8V voltage regulator IC6;
    I would presume that the reason you are replacing the capacitors is that you suspect anyone of them to be defective. But other than capacitors, have you considered also the regulator L7808CV? If the +8V is low or under current, then you would have fluctuating +8 supply in the early stage of the RF amp (Q4) and RF source (Qs 701 & 702). There is also a zener tied to the 8V line, D18 (?).
    I have a schematic but postal service from my country would take 22 days to reach US, FedEx can do in 48-72 hours but kinda expensive (30USD). I will try find a downloadable schematic.
    Cheers.
  • Louie  Role
    and the link to a schematic of a Uniden PRO 510-XL..
  • Louie  Role
    That's what dads are for. LOL Glad that it's now working.
  • 709 Answers
Hi
It sounds like your circuit board may have a bad solder joint. Sometimes during manufacture of the ciruit board, the joint could not be perfectly made. This will limit conduction and create heat which will worsen the effect over time. If you are familiar with opening and working with electronics then I suggest you remove the circuit board and inspect it for cold solder joints. When you find one, you can use a Cigar Torch type lighter to help reflow the solder easily. Out side of that, you mayu want to send it to a Electronics repair shop to do this for you. Let me know more and I will help. Good luck
  • Greg Stokes
    Greg Stokes Jan 19, 2008
    Benimur,
    Thats ok, your input is good and thank you for the comment.
    rdwOyoc,
    When looking for Cold Solder joints, I use a 30 X jewelers loupe and bright Flash light to get a really good look.
    How old is this CB?
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
How to add talkback to a uniden pro510xl
68 to 200 ohm resistor to the postive side of the speaker to board ground
Jan 28, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
What do you clip to turn up the power on a uniden pro 510 xl new style
hi you cannot tweak anymore output power from these radios as ajusting any components will damage the rig ,they come factory set at 4watts tweaking it anymore will after prolonged use damage the finals /pa transistor so leave it well alone if its not broken dont fix it goodluck
Oct 27, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl transmitts slightly off frequency. Is there an adjustment for this?
Yes, you need a frequency counter to get IFfreq back were it needs to be. google cb shops in temple, tx
Aug 07, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
TWO TRANSISTOR IN THE RF OUTPUT STAGES ARE MISSING.....TYPE? CIRCUIT DIAGRAM? PRO 501 XL.THANK YOU
Hola santipatag!
I have found two schematic diagrams that are very close to your radio. one is a lessor model and the next is one that is a bit fancier than yours. I would think the output stages would be about the same with maybe a SWR sense function.
Please email me and I will return the diagrams directly to you..... Here is my email
poikaa@yahoo.com
Hasta Luego mi amigo! Rod KB8DNS
Feb 19, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl when hooking it up imediately blows the fuse like a dead short but if i hook up another radio it will work fine
The radio was probably wired backwards at some point. There is a reverse polarity diode inside that must be replaced to fix this. If you have continued replacing fuses and plugging it back in, there may be further damage such as finals or audio amplifier chip as well. you will need to take the radio to a qualified repairman for service. If it is simply the reverse polarity diode, your bill should not be more than an hour's labor charge.
Feb 06, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Uniden PRO510XL Outup
The Uniden 510 xl is quite possibly the easiest and one of the loudest radios I have ever pumped up .Now here's the problem it's been atleast ten years since I've had the cover off one so I can't tell you which diode # it is you clip for the modulation I know that as your looking at it (speaker side up ) it's about halfway on the right hand side buy the audio transformer.Then you change the resistor buy the final transistor , you go higher until you get where you want it , going higher is going to bring your output wattage down ; I usually tried to get it down around two watts . By doing just these two things and maybe a little adjusting you should be able to deadkey 2 watts and swing to 18 watts with just that cheap stock mic. if you change the final transistor I've seen them swing to 35watts.They are fun cheap radios that when you do this no one beieves that that's all your talking on . Good Luck !
Jan 24, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL 40-Channels Base CB Radio Logo
615 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
