Question about Samsung Digimax A402 Digital Camera
Having trouble with turning it on
When I push the power button the little green light just flashes but nothing turns on? I've tried making sure the batteries are in correctly and tried changing them a hundred times-but nothing.I've had it for six months. Is it shot allready?
  • 1 more comment
  • Anonymous May 21, 2008
    exactly, i hold the on button... but the little green light just continues to flash, but nothing turns on.
  • Anonymous Jan 18, 2009
    My camera's screen and doesn't turn on. But the green little light still does.
    I recharged the rechargable batteries and put them in my camera again. Still, didn't work. The green light comes on and stays on but the screen shows..nothing. When it first went out, the lens were out, and i was just about to take a picture. It just turned off then and there. Therefore the lens are still out. I have no clue what to do. I'm really really scared because i haven't even had it for a year. HELP PLEASE!
  • dezi101 Apr 01, 2009
    when i push the power button the camerea don't come on and i be pushing the button real hard or hard enough so it could come on
Try changing to rechargable batteries. I had exactly the same problem. I used recharable they run out so tried various types of alkaline batteries but the camera would not turn on. Getting the flashing green light. Charged the batteries put them back in and working again
Posted on Jun 28, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Have the phoenix s35015 scooter. The battery is charged, put it in the scooter and turn key. All power lights up to the green, lightsheadlight can come on and horn beeps when pushed. The red light does...
make sure you put it in "gear" completely sometime you can get it almost locked but its still in freewheel, flashing light is error code, do a count of blinks and stops, look in the back of book for trouble codes
Oct 01, 2017 | Drive Medical S35015 Phoenixcompact...
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Light flashing and tv won't turn on
you might want to have the power transformer checked to make sure its working correctly.sometimes when they go bad all you get is the flashing light
Oct 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green light
check horizontal o/p&osc
Mar 11, 2008 | Televison & Video
Samsung Digimax A402 Digital Camera Logo
314 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
